Should the front window channel run all the way down like te rear channel? Mine on both doors are only about 10 inches long. Not rusted away either. Pic attached
I think it should go all the way down to the end of the metal channel. I can see corrugation marks that indicate there was something there orignally.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
