6 members (Wickedbass, jkreiner, mvigo, Charles in CA, Rusted Nut, 1 invisible), 75 guests, and 3 robots.
Topics128,074
Posts1,055,913
Members48,429
#1492505 03/16/2023 8:05 PM
Big Bolt Forum Moderator
Did they ever make a different size input shaft for the SM420?
someone asked me about the size on one I am selling, said he needs the bigger one, that was used on semi trucks!
I think he is yanking my chain as I have never heard of anything other than the 1 1/8 10 spline input shaft but, I wanted to ask, as I, of course, don't know everything!
Mike
Mike,
See the detailed description from Novak here: SM420
Nowhere in there does it describe a larger diameter "input" shaft. There is a note about a different spline/diameter "output" shaft and internals different in a rare number of these trannys.
I also did further checks on the web and found no other reference to an oversize SM420 input shaft.
I would say the answer would be a definitive "nah".
Dan
~ Dan
1951 Chevy 3 window 3100
Thee is an oversized bell housing, flywheel, and clutch assembly that's used on some of the big block gas V8's in dump trucks, but I think they're set up for heavy duty Clark or Spicer 5 speeds. I don't recall ever seeing the big input shaft being used on a 420.
yes, I have read Novak's site, and actually have 5 extra SM420s laying around, I have never seen anything on the internet referencing a larger input shaft either.
Mike
Crusing in the Passing Lane
I have also never seen a 420 on anything larger than 1.5 ton truck, larger truck(GMC) for example would have some NP-or GM or other 5 speed.
465’s different.
Ed
both of my viking 60s have SM420. (55.2 and 58.)
Mike
69Cuda #1492558 03/17/2023 12:45 AM
My 1956 Chevrolet 8400 (2-1/2 ton) has a SM420 with the standard 10 spline input shaft...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
GMC lists 4 different input shafts for the SM 420 I don't know what the difference is. I own several 350 GMC with a SM420 as well as one ton and 3/4 ton pickups.
https://photos.app.goo.gl/voCAihTogync4tNi7
In looking through the Hollander, it appears that 1948-1959 SM 420 is the same, but it was different when it was used behind V6 GMC and V8 Chev in 1960-1962. It also looks like it applies to 1958-1959 Chev with a 348. These would be very rare because most trucks this size wold have had a 5 speed.
I trust the GMC master parts book and Hollander than I trust Novak's information.
69Cuda #1492873 03/18/2023 10:54 PM
Understood about there being a bunch of different part numbers for SM420 input shafts, as well as some of those numbers noted above that have been superseded by newer numbers for the same parts.
I could not find any reference to the "2387442" number, but did find an additional number "3787254" that seems to have been used from '62-'67.
Quite a rabbit hole to go down to chase all that info down. What I did find and saved some snap shots for posting later if anyone is interested, is there are 2 different input shaft part numbers listed for SM420s of various years/series that had the added description of "(1 1/4" shaft dia.)" tacked on the ends of the part descriptions. Primarily noted in the Chevy books from Oct '62 and May '79. But it doesn't indicate what this "1-1/4" measurement applies to.
Is it the actual OA spline shaft diameter, or possibly the diameter associated with mating up to the main gear shaft and bearings? I couldn't tell and further checks to try and see if their was a clutch disc with a corresponding 1-1/4" spline shaft opening (instead of the more common 1-1/8" shaft) left me scratching my head too.
I am going to let anyone else interested take a stab at this.
Dan
~ Dan
69Cuda #1492882 03/18/2023 11:59 PM
interesting, he did say these are in 1962 C60 trucks, and sent me a pic and asked if I could not see the difference! (Kind of hard via a pic, and not not having the two side by side)
looks a bit larger than the smaller one
Mike
Originally Posted by buoymaker
Paintshop edit. I can't see much difference in the splines but the shaft tip is different.
To get a better idea, clean shafts and measure several points with calipers.
They are not mine, if they were, most definitely, I would clean and actually measure them! In one of the posts above , it looks like they made an 1 1/4 10 spline, so, that may be the one that the shaft tip looks bigger on.
Mike
Insomniac
Insomniac
I replaced my 1950s SM420 with a 1967 model. The new one simply bolted right in so the input shaft diameter, number of splines and pilot bushing diameter were all the same. However, the input shaft is different internally. The old one used a spanner nut as a bearing retainer and the new one uses a snap ring. Also, the new one was machined for a proper oil seal. So, the part numbers would be different.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
