4 members (klhansen, Eisenholtz, homer52, Otto Skorzeny), 69 guests, and 4 robots.
Topics128,023
Posts1,055,371
Members48,420
#1492478 03/16/2023 5:40 PM
Leo
Offline
Moderator
Moderator
My truck is a 1986 C10, stock, 305 V8, TH350 3 speed. My new camping trailer weighs 3400 pounds, single axle. I would prefer a 3/4 ton truck, but this is what I have. I already have the electric brake controller. Would a rear anti sway bar be necessary? Anything else?
Leo #1492483 03/16/2023 5:52 PM
Big Bolt Forum Moderator
use weight distribution and anti-sway on your hitch setup, that will help a lot more than a sway bar on your truck.
Mike
Leo #1492484 03/16/2023 5:52 PM
As long as your tongue weight is within spec (~10% of trailer weight), there's no reason that a half ton won't handle that trailer. When you start getting into trouble with sway is when the trailer isn't level when hitched up or the tongue weight is out of spec. Give it a test run and see if you need an anti-sway bar (I'm envisioning a shock absorber type connected between truck and trailer.) An anti-sway bar on the truck's rear suspension isn't needed and won't help much with trailer sway.
Leo #1492491 03/16/2023 6:33 PM
Leo
Offline
Moderator
Moderator
Thanks, two helpful responses. I am getting the anti sway hitch setup when I pick up the trailer next month.
Leo #1492500 03/16/2023 7:14 PM
I routinely tow 8K+ pounds on a 16 foot dual axle utility trailer, with an 04 RAM 1500 pickup (1/2 ton). That has included two 6K+ crankshaft grinders, one from North Carolina to Tennessee, and a similar machine from Texas, plus the weight of the trailer. The trick is to load the trailer correctly, use a weight equalizing hitch such as a Reese or Valley Tow-Rite, and having a healthy respect for the load. Stopping distance and handling in turns needs to be your primary concern. Getting the load moving isn't much of a problem- - - - -stopping and steering safely needs to be your first priority. A sway control is nice to have, but I haven't used one in over 20 years, back when I was towing a 22 foot camp trailer pretty regularly. Something with a lot of square footage on the sides, such as a camp trailer, tends to "weathervane" in a cross wind a lot more than a utility trailer. That's where a sway control comes in handy.
Leo #1492501 03/16/2023 7:17 PM
Leo, the weight distribution hitch will help with "porpoising" and make it ride smoother (less up and down movement at the actual hitch ball) The anti-sway part of the hitch helps it track straight. I tow a 35' vintage travel trailer with my 58 viking 2 ton and have both weight distribution and anti-sway on the hitch and can tell a big difference if I don't have them both on.
Mike
Leo #1492517 03/16/2023 8:57 PM
Crusing in the Passing Lane
No negative tongue weight!
Ed
Leo #1492543 03/16/2023 11:38 PM
Moderator
Moderator
2 Offline
All good advice Leo!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
