7 members (Sjm, Gdads51, JoergK., Hotrod Lincoln, KEVINSKI, cmayna, 1 invisible), 88 guests, and 1 robot.
Topics128,260
Posts1,058,313
Members48,485
#1491665 03/11/2023 9:07 PM
1953 ,216 , 9" clutch, is there a certain distance the throw out bearing is supposed to be from the pressure plate?
1953 with a 216
When the clutch pedal is all the way up, the throwout bearing should be JUST clear of the pressure plate fingers. If you adjust the linkage per the service manual, that's where it will wind up.
