4 members (Bill Hanlon, Hotrod Lincoln, Brian Moore, Hush), 50 guests, and 3 robots.
Topics128,090
Posts1,056,026
Members48,432
#1491585 03/11/2023 1:39 PM
Hello,
My name is Don and I am a new poster on here. I’ve been looking over much of the material here for awhile, but thought it was time to say hello and to ask a question. I am doing a complete ground up restoration on my ‘51 3600. The engine was a decent runner when I got the project, so I have just been going through it without rebuilding it. In a moment of stupidity, I broke off the return oil line mounted on the rocker shaft. See photo. Before I start disassembling the rocker shaft, I thought I’d check and see if anyone else has ever had this problem and has a good fix without tearing into it.
Thanks!
Don
Thanks for the insight. I’ll get it off of there and see if I can solder it. If not, I see a couple on eBay right now.
Thanks again!
H Online: Content
Don't discard that one. It's very "fixable", but it will need to be removed from the rocker shaft so it can be clamped in a drill press vise to remove the broken off stub. Then the same tube can be plugged into the hole and silver soldered back into place. It might require a little careful re-bending to make it fit and clear the rocker shaft after the soldering job.
