1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1491483 03/10/2023 5:13 PM
I have a new complete floor pan for my 49 AD . the front corners where it gets welded to the door post it has an indentation that looks like it is where the post should fit . However it does not measure out to the right spot. My original was all rotted away in that area and i dot see any proof of it being there on all the pictures or actual trucks I have looked at.
Thanks, for any assistance.
Buck W.
Do you have a specific question? I am not sure what you want to know.
Pictures of what you are describing would be very helpful as well.
Do you know the vendor/manufacturer of the new floorpan?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Buck, If you're wondering what the height of the floor should be at the front pillar, check out the Factory Assembly Manual. That will give you heights for various items on the front pillar reference to the floor. As far as horizontal location, hang the doors on the hinges and adjust the gaps before welding the floor in place. The repop rocker panels I used (part of your floor assembly) do have indents at front and rear, but I found they didn't exactly line up with the pillars.
Thank you . That was my thought, but i was just hoping someone else had ran into this issue . I bought the pan from rock auto clearance a few years ago and after a divorce and move just now starting to set every thing up to work on it.
