8 members (cmayna, Wally / Montana, Shade Baby, Goach2, Donf, dt235sd, Otto Skorzeny, Joe H),
60
0
Mod | | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | Howdy, I want to remove some light rust (or encapsulate it??) and then put a finish coat on that. It won't be seen so I don't need perfection. I would like to spray it on to get into the crevices, etc. Is their one spray can that would do it all?
What do you truckers find to work best?
Greatly appreciate!! | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I am a fan of using a wire brush to get off anything loose, then wipe it down with acetone, then use Rustoleum rust encasulator primer.
The primer does not age well, so I would spray something over it, but I have not found anything that doesn't stick to the rustoleum stuff. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Maddoggee Might use Por 15 in there where sun wont get it,used there primer on a fuel tank out in the sun,still OK after 5 years. | | |
