5 members (lumbersawyer, tclederman, TUTS 59, 39Master85, 1 invisible), 38 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
#1490792 03/06/2023 4:28 AM
Three of my trucks original rims have elongated studs holes and am having trouble finding replacements that fit the 4.75” hubs. I’m wondering if the 5.25” hub from a 54 or later uses the same bearings and will fit on the 53? Would that be consider cheating on a restoration project? Also, the brake drums would need to fit existing shoes.
Last edited by Greasy knuckles; 03/06/2023 4:33 AM. Reason: To add brake drum note
Crusing in the Passing Lane
If the bolt pattern is the same, use the later wheels with a spacer. AA makes such. State truck in your description, pictures always help!
Probably need to supply dimensions!
Ed
I’ll check the bolt pattern when home. Who is AA? Thanks
Advance Adapters
Great, will check it out, thanks.
Greasy knuckles I don't think much is considered cheating on these trucks if you can get on the road. If it's safe do what you have to to get running and have brakes !
