2 members (50Chevy3100, 41 chev), 143 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#1490752 03/05/2023 11:02 PM
This heater was installed in my '46 1/2 ton, but I can't confirm that it was original (research indicates that heaters were dealer installed options). All that I do know is that the little badge between the (missing) front panels says "Hadees V8". I have googled that name with zero results. I presume it is a 6-volt fan motor. Also question why there are 4 pipes on the core instead of the usual 2.
Would appreciate any help to identify this guy. I plan to have it rebuilt to maintain some originality, but the missing front panels may be difficult.
Last edited by Peggy M; 03/05/2023 11:26 PM. Reason: Removed img link ... not necessary with Attachment Mgr
46Nadine #1490756 03/05/2023 11:56 PM
You are correct in that all heaters were dealer installed, but that is not a heater that would have been "original" to your 1946.
I had a picture of the one from my '46 but cannot find it right now.
That heater was intended for a F*** flathead V8. Those had a split cooling system with 2 water pumps.
Steve
Steve
1946 1/2 ton
46Nadine #1491779 03/12/2023 8:31 PM
Thank you Wheelie - explains why google searches always came back with references to F***, the 4 pipes (two of which had been capped off), and the V8 badge. Knowing all this now, it seems most likely that an "original" heater would have been a Harrison. The search continues.
Thanks mucho for this valuable info.
Rick
46Nadine #1497230 04/19/2023 3:31 PM
I’m not sure but looks like an Arvin heater missing face plate.
Moderated by  klhansen, Rusty Rod
