0 members (), 256 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#1490567 03/04/2023 4:38 PM
Hello, I need to replace the rocker arm oil line on my 216. I've read the 5 step process to follow in one of the online shop manuals but have a couple questions. I assume this can be done with motor and pan in place and after I drain the coolant below the lower oil line block connection on the left side? Any other tips/tricks to be aware of?
Thanks in advance.
Thread a piece of stiff wire like an acetylene welding rod through the old line to act as a guide to get the new one through the water jacket. Be sure to leave plenty of extra length at both ends to allow for gradual bends before soldering the line to the "through the block" fittings, and DO NOT use steel brake line- - - - -only 3/16" OD copper tubing. Steel line will rust out from exposure to the coolant. Good luck!
I bought the rocker arm oil line kit from Jim Carter. It is a fairly simple installation in theory but a bit difficult in practice, didn't have to do any soldering, used teflon tape to seal the threaded fittings that go into the block, then the hardest part was getting the bends in the copper tubing just right so that I could get the tubing up through the little hole in the head to reach the fitting from the rocker arm and still be able to fit the push rod cover back on with no rubbing on the tubing. The other end of the line was also kind of hard to get bends correct so that I could line up the fitting to oil line block. It felt like an accomplishment when I finished and didn't have any kinks in the line. No oil or coolant leaks so far. I have a 1937 216 engine.
Using threaded fittings under the pushrod cover usually causes an interference problem between the line and the sheet metal. It's a lot simpler to install a brass 1/8" pipe thread plug into the block with a 3/16" hole drilled into it, and solder the line to the plug. It's a lot less likely to leak coolant into the oil that way, as well.
Great advice! Thanks all.
