1 members (Hotrod Lincoln ),
72
0
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,049
Posts1,055,680
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
I am looking to buy a exterior sun visor for my 1951 chevy 3100 any ideas on the best one to buy.
My two choices are the Dietrich sunvisor And Fulton 800 series sunvisors.
Dietrich visor
Not sure I have seen a Dietrich before. I like that.
Thanks for the info on the sun visor so now best place to buy one of these. Dietrich sunvisor And Fulton 800 series sunvisors.
The usual places, swapmeets, ebay, Craigslist, Facebook, and forums like this one.
miller ashland Are those visors made of steel or aluminum ?? Do they adjust for width in the middle ??
I am new on the sun visors not sure if they are made of steel or aluminum oradjust for width in the middle.
From what I have read on-line, Fulton are Aluminum, Dieterich are steel. '49-52 Chevy visors were made by Dieterich for Chevy/GM. For all visors, the end brackets are unique to Truck or Car, so watch out for that when you get the end brackets. The best one to buy may be the one that you find available. They do not seem to be adjustable for width, some are too wide for our trucks.
Yes, Fulton is aluminum. They are not adjustable . The Sun Shield & side "dog bone" brackets are aluminum. The mounts are stainless steel.
1950 Chevy 3100
Both visors are adjustable for width. There are holes in the center panel that holds the two outer panels together on the deitrich. The fulton has two rods with holes that holds the panels together. On both visors, select the holes that best fit your application
Moderator
Moderator
My Fulton was adjustable for width. Exactly as noted by modiol.
