| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | Hi,
I’m looking for a picture of the correct id plate for a 1940 Chevy PU. I see that a number of venders sell them but they seem to be different as to what and where the info is stamped.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | Mike
Be sure you check with the powers that be (your state DMV) on replacing a serial number plate. To do otherwise could lead to real problems legal-wise.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 5,863 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,863 | Mike, X2 to what Kevin posted above. It is illegal  to remove/replace a vehicle serial numbered VIN or data plate in most if not all states to the best of my knowledge, with only a few special circumstances which are covered by each states applicable laws. Please check with your state (Florida) DMV before taking any action on this topic. You will hopefully be able to avoid any "Legal" issues before they happen. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I had to obtain a bonded title in order to get my 1954 Suburban registered in NC (5-7 years ago).
I had the NYS title and resignation in my name.
BUT
The door-frame VID-plate that had been removed and replaced by me when the Suburban was painted. He could tell that the attachment hardware was not original.
The DMV officer did not have to offer me the opportunity to obtain a bonded title; but, I have so much documentation he was willing to offer me this option/opportunity.
He actually visited my house/garage. He had told me that there was a code stamped on the frame - I told him that no code was stamped on frames until 1956. I showed him the frame on the 1954 5-window pickup (with Hydra-Matic transmission) that is in primer and is ready to paint. I could move the cab (to see the frame) because all parts are in primer and are ready to paint.
I hope they will let me get a bonded title for that 1954 5-window pickup, too. | | |
