| | | Forums66 Topics128,094 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14898 09/14/2003 3:41 AM | Joined: Aug 2003 Posts: 14 Junior Member | | Junior Member Joined: Aug 2003 Posts: 14 | I thought that 1960 and 1961 frames on chevy pickups were diff from 1962 to 1966 but the other day I ran into someone with a 1963 and he said that 1960 to 1963 all had the same frame. can anyone help? The reason for my concern is that I have a 1961 chevy 4x4 and I am trying to covert it to a V8 and cant find motor mounts. but if 63's have the same frame I can get a parts pickup Thanks and any help will be greatly apprciated Thansk again Brian :confused: | | |
#14899 09/14/2003 4:14 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Brian, The 1960-62 Chevy trucks had the torsion bar setup up front, with a "X" member in the middle of the frame. The 1963-66 Chevy trucks had coils up front. The only thing a '63 has in common with the 60-62's is it has the same sheet metal. If you want to drop in a V8 all you'll need is the motor mount brackets oout of a 67-72 Chevy truck, and will have to drill some holes, other than that you should be ready to drop in a V8. Also are you gonna put in a automatic, or keep the manual transmission? Also is it a original "K" series 4x4? Most of the ones around here are on late 70's Gm truck chassis. David
My truck don't leak oil, it just marks its teritory.
#14900 09/14/2003 5:36 AM | Joined: Oct 2001 Posts: 39 Member | | Member Joined: Oct 2001 Posts: 39 | Yeah listen to chevy dude he is very correct just change the motor mounts and drill couple of holes it'll do.The torsion setup was only for 60-62 becuase supposedly gave a better ride. GM scrapped it in the end of 62 :confused: cuz it wasn't cost effective so went with the ol' coils up front. On another note I dunno if anyone has this setup on a 65 or something but I was ponderin about putting a 350 out of a burb and a T-5 outta s-10 I just love the sound of an 8 but just an idea I was crackin at.
BIGGY
1965 CHEVY "BIG RED"
#14901 09/14/2003 7:03 AM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | The 4-wheel drive trucks (GMC/Chevy) all have the same frame, which is the ladder frame, which is different than what was under the 2-wheel drive trucks. Also Chevy used the SB V8 from 1960-66 so you just need to find a spare parts truck that had a V8. also I guess you mite find them from one of the old part vendors. | | |
#14902 09/14/2003 11:48 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | As Jolly says, the 4x4's have nothing to do with the torsion setup. Check your assembly manual,(mine's not here!) and get the P/N for the mounts. LMC may have something possibly. The junkyard will for sure!  | | |
#14903 09/14/2003 4:41 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | FYI, 1960-62 pass used the same engine mount brackets as PU.
See the USA in your vintage Chevrolet! My Blog | | |
