Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, crenwelge, Wayne67vert), 182 guests, and 5 robots.
Topics128,282
Posts1,058,494
Members48,490
Junior Member
Junior Member
I just purchased a 1955 first series Chevy 3100.
The six cyl block casting number is - 3836848.
So far, I have not been able find it on any ref sheets online.
The flat surface behind the distributor base reads - 0064735F55X
Can anybody help me out with these numbers?
Thanks, Steve
Junior Member
Junior Member
The number you listed is for the cylinder head only. The block casting will be near the starter, or behind it. For a '55 it may start with "CON", then there is a stamped number right behind the distributor. Good luck.
Junior Member
Junior Member
I just relooked at your post, the "F55" in the stamped number would be June 1955.
Junior Member
Junior Member
Thanks - I'll look for the other number by the starter.
Tha stamped number by the distributor is interesting. I thought they stopped 1st series production in March of 1955 but the motor stamp is dated June. Anyone have any ideas?
I'll post the block number tomorrow when I find it.
In case you can't tell this is my first attempt at refurbishing an old truck. I'm starting at zero and have a lot to learn.
Thanks, Steve
Junior Member
Junior Member
You are correct, March or April was the date I have always used as the stop date. The head number is also a later part, from '56 on I've been told. Your truck may have had an engine swap somewhere in it's history. The "848" head has higher compression than the "913" head that was on earlier models. I have a '55 here with a "913" head on it but I also have a '56 here also with a "913". Then I have a '58 motor with an "848" head mounted on it. Go figure and good luck.
Junior Member
Junior Member
Thanks for the information.
I have the original title and the serial number listed on it, is the same number that is stamped near the distributor. So I think the block is probably the original one. Someone could have swapped heads on it.
I have a lot to learn about these things and with so many variables it sure keeps it challenging.
Steve
