3 members (klhansen, BC59, homer52), 123 guests, and 0 robots.
Topics128,113
Posts1,056,618
Members48,450
I am new to the site and have been looking at many posts.
I am working on a 1952 3100 and want to get rid the behind seat fuel tank. I have installed a 76 firebird front clip and Chevy 350 motor in the truck. Also switched out the rear springs with springs from a ford explorer. Would like a tank that fits where the spare tire holder currently resides and also would work with a side filler cap. Anyone got a good solution?
Last edited by Peggy M; 06/20/2023 10:09 PM. Reason: added truck description to title
Welcome to the forum! Sounds like an interesting project, we would love to see some pictures.
I don't know about underbed tanks for the AD truck specifically, but Classic Industries sells a rear mount tank for the TF trucks that fits above/behind the axle and can be used with a side filler. Maybe check there?
Someone else with more AD experience might be along as well.
Again, welcome to the community.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
This might do the trick for you?
Underbed Tank
Patharr,
Welcome to the Stovebolt and our hobby (passion, madness, addiction - you get the picture grin ). thumbs_up
You truck sounds interesting and much like what has been done to many fellow 'Bolters trucks.
In addition to posting questions on your topics in the forums, you might also try and use the Search the Site tool to see what has already been discussed on your subject. You may find some solutions to what you are seeking in there.
See you in the forums! wave
~ Dan
1951 Chevy 3 window 3100
I believe in the 3100 a number of people have used a Blazer fuel tank.
I was not able to pursue that option on 3600 because the frame spacing is much narrower but if you search for my thread on under bed fuel tank options I believe you will find several suggestions that should work for your 3100.
1949/50 3600 Project
Follow in Project Journals
What year of Blazer tank? Any pointers to links on the site describing the process?
https://www.stovebolt.com/ubbthread...r-bed-fuel-tank-options.html#Post1484309
There is some good discussion of a few options there.
