2 members (2-Ton, Gdads51),
107
Mod | | | Forums66 Topics128,093 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 14 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 14 | I am new to the site and have been looking at many posts.
I am working on a 1952 3100 and want to get rid the behind seat fuel tank. I have installed a 76 firebird front clip and Chevy 350 motor in the truck. Also switched out the rear springs with springs from a ford explorer. Would like a tank that fits where the spare tire holder currently resides and also would work with a side filler cap. Anyone got a good solution?
Last edited by Peggy M; 06/20/2023 10:09 PM. Reason: added truck description to title
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Welcome to the forum! Sounds like an interesting project, we would love to see some pictures.
I don't know about underbed tanks for the AD truck specifically, but Classic Industries sells a rear mount tank for the TF trucks that fits above/behind the axle and can be used with a side filler. Maybe check there?
Someone else with more AD experience might be along as well.
Again, welcome to the community. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | This might do the trick for you? Underbed Tank | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | Patharr, Welcome to the Stovebolt and our hobby (passion, madness, addiction - you get the picture  ).  You truck sounds interesting and much like what has been done to many fellow 'Bolters trucks. In addition to posting questions on your topics in the forums, you might also try and use the Search the Site tool to see what has already been discussed on your subject. You may find some solutions to what you are seeking in there. See you in the forums!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 2021 Posts: 1,386 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,386 | I believe in the 3100 a number of people have used a Blazer fuel tank.
I was not able to pursue that option on 3600 because the frame spacing is much narrower but if you search for my thread on under bed fuel tank options I believe you will find several suggestions that should work for your 3100. | | | | | Joined: Nov 2020 Posts: 14 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 14 | What year of Blazer tank? Any pointers to links on the site describing the process? | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | | | |
