| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | D-70 and 80 disc brake rear axles come with the GM 5/10 on 7.25” bolt pattern. ‘91 - ‘01 P3500/P30 disc brake front hubs/spindles with 5/10 bolt pattern can be adapted to older axles.
Ed
