4 members (Phak1, Greg_H, WICruiser, tclederman), 84 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
i'm making some spring plates to convert my boys 52 pickup closed drive to an open drive. i've done this before but can't remember, so the rear axle NEEDS to go back 11/2 " from stock?
thanks Jay D.
jay d,
Going to move your post to the Driveline forum as that is the best place to have this discussion.
Dan thumbs_up
~ Dan
1951 Chevy 3 window 3100
Jay
If you want the axle in the stock location you need to put your center bolt holes in the spring plate forward of the center of the axle housing. The center bolt (and axle pivot on the torque tube) is forward of the axle center on the stock axle. In other words, the axle needs to be behind the center bolts on the stock springs.
THANKS, but how much does it need to be moved back? I'm thinking 11/2 but not positive.
Jay D.
Sorry, I haven't measured the distance between the axle center and the pivot. And I can't go do that for you until the pile of snow melts off the chassis. frown
1 1/2" is best. I believe I did mine at 2" because I wanted the slight allusion, with the axle slightly forward in the opening, of forward motion. "Going fast while sitting still" I guess you would say?
2" behind the center pin would put the axle farther BACK in the opening than stock, wouldn't it?
Moderator, Electrical Bay
I used 1.25" although I could have used 1.5 just as easily. 1.25 worked a little better with the perches I had. Actually you can use 1 inch if you wish. The difference between 1" and 1.5" won't actually be seen by the eye as much as you might think. 1" will let you pick up a wee bit shorter turning radius...again not enough to make much difference.
~ Jon
Moving the hole in the perch forward of center, would push the axle to the rear. At least that’s the way I have it figured.
1951 3100
Ah, I went one way or another! That was almost 17 years ago!!
I am with you on that. It makes my eyes hurt to see the wheels centered in the wheel opening. A pet peeve of mine I guess.
I am thinking that they were originally place in the forward-of-center position to help keep the mud under the fenders. Very few paved roads back when these trucks were new.
