Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (crenwelge, JW51, FishinToms53, KEVINSKI, klhansen), 122 guests, and 3 robots.
Topics128,275
Posts1,058,570
Members48,492
Page 1 of 4 1 2 3 4
I
Retired Construction Worker
I Offline
This is a place we can share with one another Tinkering Projects we built other than what we have done with our old stove bolts .
We can share photos or just thoughts about our own Tinkering or reply to others in here about their Tinkerings. This swing is one I built from lumber scraps I drug home from construction jobs ..
Edited September 1, 2023 by Peggy M: We really want pictures. Thoughts are helpful. And explanations are good. But the reason for moving this topic out of the Spoon, as discussed by the Moderators, was to allow for pictures. pix
:nopics:
Larry's tinkerings
Directions are just another man's Opinion
My other tinkering projects almost always involve a vehicle of some sort. One of my recent non-vehicle projects was hauling approx 30 bucket loads of asphalt tailings with my small Kubota backhoe. There has been probably 200 tons of tailings piled directly across the street from my house for over 10 years. Various entities have at times come in and got a load or two. The whole lot recently sold to a person I know and he told me to take what I needed. So, 30 trips across the road and back to my 30X50 equipment barn. Makes for a nice mud free floor and all it cost me was time and diesel. Now it’s all for sale by the truck load and hopefully by the end of summer I won’t have to look at it anymore.
Is that like ground up pieces of asphalt? Did you spread it like gravel in the driveway?
1950 Chevrolet 3100 (Ol' Roy)
I
I Offline
My dad knew the county roads supt and he let my dad have some asphalt left over from road surfacing that was still hot enough that one could shovel it into dads car trailer and haul it home a short distance and use it.. We put it on the dirt floor of a chicken house and I used a something to beat it flat ..May be 4 inches thick or so,,, it was warm enough that it smoked or steamed .. If it hardens back up after being hot to use for road work ,,you cant use a pick to break it apart..
back yard wrench turner
As I mentioned in the other thread, I'm currently working to restore a boat.
It's like one my parents had 60 some years ago. It was destined for the dump. I drove 900 miles to Columbus, Ohio to pick it up in mid January (in the snow!)
The wood inside was totally rotten. I've cut it all out and have replaced almost all of it. I still have the transom to go.
As found, and current:
Wayne's boat project
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Yes, it’s ground up asphalt road material. I spread it about 3-4 inches thick on the barn floor.
A bit more work on the Mini-Bolt. Got the accessories glued onto the engine. Still doing a little body work on the cab. It came as a 5-window, but to keep it correct to my truck (a 3-window), I glued in the corner windows and am smoothing them off so they disappear. Chassis is almost up to where the big chassis is, although it's not covered in snow so a bit easier to work on. wink
I
I Offline
What a project It will look neat when done ,, reminds me of my 57 Chevy back end .. I had a father in law who bought a boat sorta like that and it was Sea King sold by Wards ,,it had fins on it also he kept breaking sheer pins on the motors that were on it..that was back in 1964 or so..
Wayne, the fins look like the backward ones on a '57 Cadillac.
Are you going to restore it or build it to your specs? By that I mean do you have all the interior stuff like the steering wheel and throttle control, etc?
I'm confused. Did you sand off the brown paint to reveal the green? Looks like they used the same paint on the house trim.
I'm restoring to original. It needs new steering, wiring, lights, cholks, and seats. I hope I can get the motor to run.
The brown was red at one time. The green is the original color just like my parents boat. See photo below.
Wayne
1989 Silverado
The kids are entering a pinewood derby in a couple weeks and just found out there is an adult category so they talked me into starting a car. And by "car", of course I mean "truck" because they are inifintely superior.
I took a couple hours this afternoon and roughed it out. Now the glue needs to dry so I can profile the fenders and get it primed.
I need to use the scroll saw more, it is rather relaxing.
Jason's pinewood derby entry
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
24601
24601
Wayne, You had asked about my boat restoration project. It's ongoing...
Mine is a 1970 Boston Whaler Sakonnet. I tried to keep the old motor going (Evinrude 90 HP) but after a $400 towing bill, I elected to repower the boat in '19. Here's a few pics. Some wood working was involved to restore the center console and the bow casting platform. A LOT of fiberglass work was done to the transom. And I replaced all 4 through hull fittings. A fellow 'Bolter, Bo Toepfer, did the transom repair and lent me the tool to do the through hulls with.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Crusty Old Sarge
Crusty Old Sarge
I work on most anything but really like old Tractors. This is a Ford 9600 I worked on recently, rebuilt the transmission, 8 speed with Hi and Low power.
Ford 9600
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
24601
24601
That tractor is gorgeous, Craig! Got pictures of the tranny rebuild in the shop??
Here's mine (currently)
John's shop - one of them ;)
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
That's a beauty!
Wayne
1989 Silverado
Crusty Old Sarge
Crusty Old Sarge
John, It was a greasy hog back then. After I finished the mechanical work my friend Keefe did the body work and paint.
9600 Ford Split 1
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Does having an explosion of Ford projects at my house count?
http://www.bunchobikes.com/modela1.htm
http://www.bunchobikes.com/40Ford1a.htm
When I'm done with the '40, partial payment will be a '28-'29 Tudor sedan. The body seen in the first pic of the Model A page.
After finishing Dana's '56 3100 I decided to try my hand at another brand, so I started looking for a Willy's Jeep. I found one on Craig's List about 100 miles north of me and bought it, it's a 1953 M38A1. As it turns out it was born into the US Navy, then sold as surplus to my local VFD where they built it into a mini fire truck (I never knew they owned it until the seller told me where it came from). It took me almost 5 years to complete, but I got it back to as close as I could to the way they built it in 1983.
Here's the way it looked when I bought it, then upside down with all new floors, the chassis done and the finished Jeep!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I
I Offline
If it was white from when in the Navy ,,then it could of been an Officers Jeep ,, I worked at a Camp Riley on the Oregon Coast by Seaside and there was a white on
Mike B smile
Mike B smile
It probably was an Officers Jeep if it came from the Navy ,, I bet it was in great shape when you got it,,,
I
I Offline
Thats pretty neat there.. Scroll saw is what one needs for them fenders for sure,..
Post another photo when it's done
Crusty Old Sarge
Crusty Old Sarge
Mark, I have a 67' F100 that I finishing up for my BIL. The truck is painted in the 60's GT40 style and has a 508 CI big block w an AOD. I haven't fired the engine as yet, but I had it Dyno tested at 568 HP on pump gas, I enjoyed building this engine.
67' F100
508 CI Big Block
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
I
I Offline
These Whirley Jigs are what my dad made years ago and this summer I plan on redoing them and making some of my own.
Larry's Whirley Jigs
Nice! That's a good paint scheme for that truck.
I'm trying to fire up the blown 302 in the '40 and it has been giving me fits lately. I was told it was ran on a stand. The guy who ran it is no longer alive. Since he locked out the distributor, and probably had it sitting around 30 or so, I brought back the timing 10 degrees and it wanted to kick a little better but just wont go. I feel like the starter isn't up to task, so I might try a new one. It's the last thing I need to accomplish so I can send it away to the new owners. Then, MAYBE, I can get back to my own stuff.
My new “Tinkering Project” showed up today. I promised my Bride I wouldn’t “Buy” another project. Sooo, traded little Bro the Farmall SuperA for his ‘64 CJ5. It’s a old farm jeep that starts right up.
Engine sounds fine and all drivetrain parts work. Water pump leaks, oil line to the oil canister leaks and no brakes. Other than those issues it’s perfect. I’ve been told it needs to be ready for three grandkids on spring break at the end of March.
It’s going to be a drive around the pasture and the timber company roads behind the house. Along with trips to the cabin two miles away.
RonR
RonR's ‘64 CJ5.
RonR
1970 340 Duster
1964 CJ5
I took a window scraper to the hood and was able to uncover the original Navy serial number. It was Olive Drab with Black letters...more than likely it was a SeaBee Jeep as Navy Jeeps were normally Gray like this one (my newest Jeep a 1978 US Navy CJ-5).
The white Jeep was in rough shape when I got it...I did a complete every nut and bolt restoration to put it back the way the fire department built it in 1983. The man I got it from had it covered with an old Army tarp in his back yard for 17 years and never did anything with it. The only good thing was the engine was not hurt, I had it running shortly after I got it home. Everything else had to be rebuilt of replaced...the trans and transfer case were both full of water. The floors and gas tank were rotted out, but I got it wiped back into shape!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Looking good thumbs_up What are you using to fill window gaps and such?
Just about finished stripping the 235 block in preparation for taking to machine shop. Despite a little wear ridge at top of a couple cylinders the pistons easily came right out. Also discovered this '55 block uses the easier to find main bearings without center locating nub and required matching hole in block.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Bondo spot putty seems to be working pretty well.
As requested, the final product. It has some flaws, but I didn't want to obsess.
It is finished.
Former Workshop Owner
Wow, nice job. thumbs_up Are you going to race it in an open class?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
The races were today. A grand time was had by all.
That is the color of paint I got as a test for my 58. I am planning to use that green for the main body and that silver for the grill, arrows, headlight buckets, etc.
I have to keep one of my ten 59-65 year old M**c**y outboards working for the 1959 Sande Ace runabout that my dad bought new. The shop actually helps.
The stitched panorama shows 3 walls of the shop.
Wally .... shop and ....
I
I Offline
You did good ,, looks fine.. I and my son built a race car when he was in grade school .. and another one I built just for fun.. I have them in my curio cabnet.. are you building any more cars ?
My last project was the total reconstruction and modifications to a 1960 Hunter 23’ powerboat. Originally fitted with twin 80hp Volvo I/O’s. The hull was the first Deep Vee hull design, one of the earliest fiberglass boats and the inspiration for the Bertram 31 sport fisherman.
Photos taken over a 5 year period.
1953 Chevrolet 3800 Dump Truck
I
I Offline
My father in law back in the years of early 70ies ,,had Volvo engines for his boat and he really liked them and the wife and I went out in the Pacific Ocean fishing with him.. I am not a boat person but beings you showed such a great refurbashing on your boat and talked of it being driven by Volvo's . .it made me think of what I just said
24601
24601
Idaho ... I grew up in our family-owned marina. The Volvo-Penta I/O's were what the high-end "Rich people" new boats had. We didn't sell any of those. We were lowly OMC/Johnson dealers. The *really* rich or high end folks, of course, had pre-World War Two Chris-Crafts with Gray Marine straight 8's. Our family business had a good reputation for caring for/restoring those classic Chris-Crafts. We usually did 2 or 3 every winter. I wish I had pictures ... But here's a couple of shots of where I grew up. Lake Memphremagog. Georgeville, Quebec.
Je me souviens
quebec
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
I
I Offline
Je me souviens
quebec
That is interesting ,,Quite the thing growing up around a boat business..Phots tells a lot about a place.. I grew up around Salmon fishermen on the Lower Columbia River at a littel place called Mayger Oregon .. I still have a nephew who has drift rights on the river ,,it was in about the year of 1967 or so that the father in law changed over to the Volvo motor in his boat.. I think he maybe had a chevy 2 engine before that or a friend of his did.. Funny thinking about the car motors by name were also made for boats , First he bought a Sea King made by Mongomery Wards and it had two out board motors on it.. again the wife and went out of Garibaldi Oregon fishing in the Pacfic .. on the way back he missed a buoy marker and all of a sudden I was thrown out of the boat and when I stopped I was sitting up ,,,,and couldn't understand for a minute how that could be as were in the ocean ,, he hit a sand bar and broke both shear pins in the two motors
I guess I can chime in here… I tinker. I like tinkering. I want a shop just dedicated for woodworking but my woodshop has morphed into a truck shop, a bike shop, and antique machinery restoration shop. I cant seem to not like perfecting a craft, and taking old things (even old bicycles) and bringing them back to life. So… I am off on a timber framing journey to build onto this main 26x36 floor for old trucks, tractors, bicycles and machines. What happened? I suddenly morphed into a Yankee coming from the Midwest, and a pile of rusting scrap and decaying logs to clean up and stick in our house, is treasure to drag home for me. John? Care to weigh in about the latter?
1946 GMC Project
"Back-in-the-day Restore"
Rustbucket Ranch
Rustbucket Ranch
Love that 841 with front wheel assist cool
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Yes. That is a 1959 Ford Elenco 4WD! Collectible in the Ford tractor world. The front axles and drive were created by Elwood Engineering Corp. they bought up the surplused Dodge Power Wagon 4Wd axles, and tied those in through an external driveshaft and transmission inspection cover. Ford eventually liked these and started to produce them in-house but most were add-ons by Elenco. 4WD’s were new and somewhat available to broader markets, but give credit to Elenco for design building these beasts.
This was done a few years ago - and I sold it on EBay to a couple gentlemen from outside Dallas who road tripped up here, took a right turn in Iowa to pick up another tractor for me. Why not? This Elenco was an all out nut and bolt resto from a tractor that was in rough rough shape. They are difficult to find, limited, look awesome and work well. Over-engineered these units were worked hard which may have affected their numbers. In the Ford tractor world the other Holy Grail would be a 1939 aluminum hood 9N. Regarding the Elenco the turning radius was too wide for my use.
1946 GMC Project
1957 Sea Fury update: I've turned the boat upside down and sanded all the old paint off the bottom and sides. I've made the 1st pass with fairing compound and sanded it smooth. Another pass is needed before primer then paint.
Wayne
1989 Silverado
Page 1 of 4 1 2 3 4
Moderated by  J Lucas
