5 members (Geo55, Gdads51, Hotrod Lincoln, papas52, 1 invisible), 97 guests, and 3 robots.
Topics128,165
Posts1,056,989
Members48,458
I am lost had a problem lost all clutch contact coming on from a ride with friends. stopped at bottom of uphill driveway to downshift into lower gear no contact to gear down, had to turn motor off shift into 1st and get into garage riding brake the whole way. after tearing down . a fellow art deco truck driver claims my rod setup to be all wrong for my truck. was wondering if any of you other 215/235 4 speed truckers had any pics I could compare the setups. my tranny was incomplete when I put things together and had nothing to go on. the claim is that the shifting linkage (rod) is not correct on my truck and causing the clutch problems .hoping someone has some pics that shows what I'm missing .[img]http://dscf0696[/img].
3B Offline
Hy Fred Jones Jr, please remember to tell us the year and model/size of the truck you are making inquiries about. I could not get your link to work?
If I am reading his post title correctly, I think Fred has indicated he has a 1941 "AM" model pickup.
According to the 1929-41 Master Parts Listing, that model is the same as the "AK" 1/2 ton pick-up, bit with a 10-1/4' longer wheel base (and guessing longer bed) with longer springs and larger 14" brakes. See: http://chevy.oldcarmanualproject.com/parts/1929_41/41cpi03.html
I can't see the picture Fred tried to link either.
Fred,
In hopes that it will be of some use, look at Figure 115 on this linked 1941 Shop Manual page http://chevy.oldcarmanualproject.com/shop/1941/41csm196.htm to see how the clutch linkage should look.
Will have to wait and see if you can provide a viewable picture and then we can try to better help with the problem.
Dan
~ Dan
1951 Chevy 3 window 3100
my truck is a 1941 chevy am 3/4 ton truck
sorry if it's all over my boss (wife) has to post the pics , my skills are very limited . yes my truck is a 1941 am with a wheelbase of 125" and a slightly larger cab, the brakes are 14" and we use the pics from the manual 114/115 to get things going. the eyebolt on my truck ws made by my machinist to mimic the one on fig 115, I have replaced the clutch fork ,wheel bearing, ball and spring. reading up on clutch and pressure plate wear they appear to be fine , so why can't I adjust my clutch to get some sort of pressure to ingage the tranny.
Looks like you have taken up all of the adjustment in the eyebolt which leads me to ask...
Do you have the correct throw-out bearing installed?
Is your replacement fork bent?
Are you using the correct 10-3/4" clutch Disc?
How much pedal free-play do you have?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
the bearing matches the one I putt in 4 years ago. the fork is a new one with some color matching paint, not bent. the clutch is 10 3/4 " , I've adjusted out to give it about a quarter " freeplay. the pics only show one spring in the setup , I have always use 2. 1 for return fork spring, 2 for adjustment of takeup pressure.
