Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (CuzzFuzz, baldeagle, Rusty Rod), 40 guests, and 1 robot.
Topics128,003
Posts1,055,244
Members48,418
#1488283 02/18/2023 12:20 AM
Hello all, today I picked up this engine, can anyone help identify what year it is? Can anyone tell me what this pad, on the right side, just in front of the fuel pump was for? Thanks in advance.
2 Offline
Got a block casting number?
Based on photos alone looks like it’s from a Canadian car
the serial number stamps font 9 and 6 are rounded leg style and the 5 is a nice bubble round on the bottom, both details of the Canadian stamping vs the USA straighter font used
And the format of the number itself matches what you would find in a Canadian car, trucks usually started with XC for example and a car was a C number
-s
I looked for the block casting number, but didn't find it, I will look closer tomorrow. Any idea of what the pad, on the right side, just in front of the fuel pump, was for?
2 Offline
No clue what the pad is for
But if it’s a late 50s engine it might just be where the factory air conditioning pump might be found , just a wild guess
The casting number will be close to that pad unless they had to move it far away to accommodate that new pad feature
-s
1955-57 passenger cars and 1955 second through 1959 truck used engine mounts on that pad.
My Blog
Side motor mounts say it's a 1958 or newer engine if built in the US...I don't know when Canadian motor started using side mounts.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy guys, my memories tell me the engines started using the "birdleg" mounts that would use those pads starting with the 55 B or second series trucks
Stovebolt_six,
Just a note that I am going to move your thread over to the "Engine Shop" for further discussion there as its the best place for your topic.
More folks will chime in to help you figure out what you have there. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
I finally found the engine casting number, as well as the head casting number. The block casting number: [img]https://www.stovebolt.com/ubbthread...umber/53319/filename/20230218_144403.jpg[/img]
The block, 58-62 235. The cylinder head, 56 261. Correct?
848 is a 235 head.
BC
1960 C60 pasture art
Moderated
Moderated
That engine looks kinda familiar…..
