5 members (Joe H, Cosmo, Otto Skorzeny, Phak1, Bill Hanlon), 128 guests, and 1 robot.
Topics128,049
Posts1,055,548
Members48,425
#1487917 02/15/2023 12:27 PM
What is the difference between a R43 and R43S spark plug? A/C Delco.
Ol'55 #1487921 02/15/2023 12:54 PM
The S plugs have an extended tip, May help prevent fouling. May also hit the piston. Use the proper plug for your truck.
Ol'55 #1487949 02/15/2023 3:23 PM
Like the slogan Sun used to put on all their equipment- - - -"We Test Not Guess". Measure the distance from the gasket to the plug tip and the distance from the gasket surface of the head to the piston top. If there's no interference, run them. The heat range is the same.
Ol'55 #1487964 02/15/2023 5:01 PM
I think the R43S is for V8 GM vehicles. (283 & 350)
Maybe someone can confirm.
What engine are you working on? 235?
1950 Chevy 3100
Ol'55 #1488002 02/15/2023 9:05 PM
Riding in the Passing Lane
The S type plugs work on o-head valve engines without interference. Should not be used on flat heads. They are much superior to the older type plugs.
George
1972 Chevy c10 Cheyenne Super
Ol'55 #1488054 02/16/2023 3:12 AM
Sorry about that there Bolters but it is a 235 6 cyl.. chevrolet. Now what is the best way to check T.D.C. with out removing the head? I have seen those tools that you thread in the head to duplicate a spark plug?
Ol'55 #1488055 02/16/2023 3:22 AM
Ol'55
That question actually is better asked in "The Engine Shop" forum please. A whole different animal not related to "The Electrical Bay".
~ Dan
1951 Chevy 3 window 3100
Ol'55 #1488056 02/16/2023 3:26 AM
O Online: Content
Take out the plugs and turn the engine over by hand with your thumb over the spark plug hole. You'll feel the compression as the piston comes to the top of the cylinder.
You can also put a straw in the hole while you turn over the engine by hand. The piston will push it up. When it reaches its highest point, the piston is at TDC.
1950 Chevrolet 3100 (Ol' Roy)
Ol'55 #1488057 02/16/2023 3:44 AM
The plugs in a 235 are at such an angle that a regular "positive stop" tool will not touch the piston. When the "UC" mark on a 235 flywheel aligns with the pointer in the window above the starter both #1 and #6 pistons will be at TDC. The ignition timing BB will be close enough to top center to check for spark plug interference.
Ol'55 #1488099 02/16/2023 4:59 PM
OL 55 If you hunt for top dead center disconnect your battery,that tool will kill your piston in an instant if you engage the starter.
