2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
#148786 10/09/2006 3:18 AM
Hey Guys,
I'm new to the big bolts. I usually hang out on the small truck forums. I'm looking at a 1 1/2 t that the owner swears is titled as a 53. I say its a 50 or older. It has no vent windows (pre 51), lever door handles (pre-52), it has a 80 mph speedo (pre-52) and SS bars above and below the radio grill (pre-52). The gas tank is in the cab. That should have changed in 49. So were the shocks on a 49 lever shocks like the smaller trucks or piston? I'd like to buy this truck but think I'd have a hell of a time selling a miss titled truck.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#148787 10/09/2006 10:54 AM
My 48 2 ton has no shocks, front or rear.
I don't know about a 1.5 ton though.
•1952 Chevrolet 3800 pickup
---All pictures---
#148788 10/09/2006 11:41 AM
Can't you just run a VIN check?
#148789 10/09/2006 12:42 PM
Shocks were not a standard item, on the big trucks. They were an optional accessory.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#148790 10/09/2006 4:41 PM
At this point I've only talked to the dealer and seen it in pics. I will do a VIN check. I wanted the shock info so that when I do look at it I can tell if it's a 49 or earlier. But, I guess that angle is out. Weren't the cabs the same on all the AD trucks? Didn't the yearly changes on the light truck transfer to the big trucks? IE, vented windows, outer handles, cowl vents and so on.
Glenn,
1952 Chevy 1/2-Ton
#148791 10/09/2006 7:22 PM
Chevrolet truck optional shocks were double action lever arm type and were usually only put on the Panel body's that carrier light loads and had the lightest option rear springs.
34 & 35 trucks are the greatest
#148792 10/10/2006 6:17 AM
Former Workshop Owner
I just brought home a '41 parts truck (1 1/2 ton) that has lever type shocks on the rear. It also has heavy rear springs along with overloads. I haven't checked the front yet.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#148793 10/14/2006 4:07 PM
J Lucas any idea what your 41 truck was used for? What body did it have? Are the shocks single or double action?
#148794 10/15/2006 5:18 AM
35 Trucker, I don't know how to tell the difference between single or double action. I did notice that the '41 also has shocks on the front, as well as the rear. There is something else a little peculiar about this truck, the grill is notched on both sides to allow for the front bumper to be mounted extra high. The notches look like they were done at the factory. Neither one of my other 1 1/2 tons (both '42s) have the shocks or notched grill.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
#148795 10/15/2006 10:31 PM
The double action shock will look like a cylinder with the lever in the middle; a single action has the lever towards the short end. Don't know what the bumper would have been mounted higher for? What body was on the 41???
#148796 10/17/2006 1:57 AM
Just a cab (no bed) although it looks like it was set up as a dump or grain truck. See link below for pictures of shocks.
http://www.flickr.com/photos/71596736@N00/271799580/
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
#148797 10/17/2006 10:08 PM
Those are double action shocks.
#148798 10/17/2006 10:51 PM
Who ever ordered that truck wasted their money on double action shocks; with the suspensions heavy springs and overloads you would never know the shocks were there. Very very unusual.
#148799 10/18/2006 4:07 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have a 53' 1 1/2 ton,here are some pics
