1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#1487737 02/14/2023 2:15 PM
There is a new post today that I believe is a 1953 Canadian 235 that got me thinking.
Do all Canadian 235/261 engines have this extra pipe plug on the side of the block?
I don’t believe any US engines have this plug.
See picture below.
And maybe a better question is, what is it for?
My Blog
I always thought it was a coolant drain plug, I’ll try to undo it tonight and see what lies behind!
And yes, it’s the factory installed 235 from my 53, according to GM!
2 Offline
Can confirm
The default 53 Canadian 235 engines
block: 5843350 head: 3701887
All have that big plug you show
I have never removed one but I’m 99% sure it’s the water jacket because I had one with a hairline crack below that plug and coolant was seeping out the block in that location.
-s
Yep, coolant jacket. You can see what I believe are cylinders 4 and 5
Thanks!
I wonder why only Canadian engines have this?
My Blog
They must be better!!! Lolol
Leo Offline
Moderator
Moderator
The Canadian engine blocks were all cast at a foundry in St Catherine's Ontario, (not very far from Buffalo). GM had purchased this foundry years earlier from MacKinnon Industries. Why they were different, who knows.
Could it be there for a block heater to mount into? Or maybe a fast way to drain the coolant in the colder climate?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
All 4 of my 235’s have the block heater mounted more towards the front of the engine, one of my engines is a 52 splash oiler and it also has that big pipe plug. Engine number is 3835814
2 Offline
This pipe thread hole is a bit smaller I think than the normal smooth hole block heater which all my engines have
You pop out a frost plug and that’s where the block heater goes
This threaded hole is always a pipe plug like the photos.
Maybe it’s for an older style block heater standard used in Canada? Anyone have old Canadian parts books? Look up block heater options
Hole looks to be about 1inch pipe thread?
-s
There are still block heaters that use pipe threads, but most I've seen would go quite far into the block and may not have room at that location. The ones that go in a freeze plug hole are usually a bent pattern and wouldn't work on a threaded hole. Here's one that might work there. Link
