1 members (baldeagle), 94 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1487611 02/13/2023 2:32 PM
I am not sure if this is the correct forum. I have some white walls that are still in great condition but have yellowed some. I have tried the standard products like Bleach White. Any suggestions on how to restore the bright white appearance? If cleaning doesn't work have any of you use any type of die or coating (paint?) to whiten them back up?
Dave from Northern Kentucky
My 54 3100
JC Whitney maybe 60 years ago?
I did just find a YouTube video where the guy uses 300 grit wet sanding and then 800 grit to finish. He then seals with a silicone tire sealer. He claims this will fix white walls that have yellowed. I will give it a try unless someone has another method.
My 54 3100
Good morning.
I use Mr clean Magic Eraser's on my whitewalls.
Makes them look brand new. But mine have only been dirty, not turned yellow.
Good luck,
Todd
1950 Chevy 3100
I saw a video where the guy used a Mr. Clean eraser. He said it worked good but fell apart very quickly and he needed several. He was also only removing dirt and grim, not yellow discoloration.
My 54 3100
They do fall apart fairly quickly.
But it makes my whitewalls look brand new.
1950 Chevy 3100
White shoe polish
I use Black Magic Bleach White in a spray bottle. I let it sit a few minutes then rinse with clean water and air dry. Wally world and some of the parts stores sell it.
The JC Whitney product looks interesting. I wonder if something like white flex-seal would work the same way.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I have and use Bleech White all the time. It for the most part does a good job. My new project the white walls have yellowed and Bleach White is not doing it.
My 54 3100
Can’t beat elbow grease. When I was in high school I always used a Brillo pad first and then used a small stiff bristled hand brush with a few drops of mom’s dishwashing soap and a dose of Comet powder. The whitewalls always turned out really white.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Use a fine grit ScotchBrite pad in a drill motor or a die grinder. Grind the yellow layer away to expose the white layer underneath. That's how the white rubber is exposed in the first place- - - -the white is covered by black rubber during the curing process. When I worked at Armstrong Rubber Co. in the early 1980's we produced 14K tires a day, and every whitewall had the white layer exposed by a grinding wheel.
Just a suggestion that you might try. I've found that Krud Kutter restores yellowed white plastic parts. Might work on whitewalls, too. Easy enough to try.
Kevin, which version of Krud Kutter? I was going to try it and there are multiple variations. Cleaner/Degreaser, Rust Remover, Sports Stain Remover and a bunch of others. I am guessing the base version, Cleaner/Degreaser?
My 54 3100
The best product I've found to clean whitewalls and keep them clean is Westley's Bleche-White. It's made by Black Magic now.
Contrary to popular belief, it does not contain bleach. Wash the tire, apply the product and scrub with a scrub brush. Don't use bleach on whitewalls or, just like your socks and underwear, it will turn them yellow.
I've been using it for over 20 years.
1950 Chevrolet 3100 (Ol' Roy)
I didn't even know there was anything other than the Cleaner/Degreaser, so yes, that's what I'd try.
