| | | Forums66 Topics128,181 Posts1,057,150 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | I'm having a tough time locating a side plate gasket for a 1942 235 truck engine. This gasket is huge, the entire side of the engine including the spark plug access holes, all covered with a fitted tin cover. Does anyone have a part number for this gasket? | | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | i think what youre looking for is a 216 side cover gasket. try asking for one from the early 50s and see if that fits. if you can,,take your side cover with you to the parts store to help match it up. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dale in Iowa, Fel-Pro p/n PS5004D hope that helps. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Also, don't forget about gasket sheets. I think Napa sells them in various thicknesses so you can just make your own. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Dale,
NAPA has the gasket you're looking for and Delux54Panel is correct.
You'll need to tell them you want one for a 216. None of their books show the early splash 235's.
I ran into the same problem, when I was searching for the gasket for my 48 235. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | You have the Fel-pro part number supplied by 3B , it doesn't get much easier than that. Even the kid with the purple hair and silver nose ring should be able to find it for you! Stuart | | | | | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Dale, I may get corrected on this. But I believe the 235 wasn't produced until 47. Then only standard in the 6400(2 ton) and an option for the 4100 (1 1/2). A 216 was used up till then. The side cover covering the plugs was only on the 216. Getting a 216 gasket for it is available from Napa.
Glenn, | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The military used 235s all through WWII. There were 3 different 235 engine blocks from 1941-1948. | | |
