3 members (BC59, cmayna, Peggy M), 144 guests, and 2 robots.
Topics128,095
Posts1,056,475
Members48,444
Page 2 of 2 1 2
Rovertech Looks like your in on "big metal toys" once done a 59 napco 4x4 ag spray truck similar to that tough truck !! Good Luck,don't let that engine overheat!!
Working on setting a time to go grab it this week. I will upload more photos to the picture link. If anyone has any specific photos or information wanted, please let me know and I will get it for you.
The link to the pictures.
Last edited by Peggy M; 02/09/2023 3:17 PM. Reason: Added picture link so folks can see.
1958 Apache 3100 Fleetside Shorty
327ci V8
1958 Apache 31
Rovertech As was said it is hard to help you without actually seeing the truck. At over 12,000$ I hope your tin ware is all straight and rust free. Buying body work services are expensive,slow,can be sloppy,and are often very disappointing. What's done is done so burn into what you have. My main consideration is a drivers door that fits the hole closes easily and securely don't have to slam it hard every time you get in !! I spent big bucks that sorry door wasn't right ... anyway hope you have good fortune with your truck.
I checked both doors before bidding, they seemed to operate properly and latched great!
327ci V8
1958 Apache 31
Authorized Pest
Authorized Pest
Rovertech,
Hope having the Flickr link in your profile will help with the questions people are asking.
~ Peggy M
1949 Chevrolet 3804
She has made her way home and into her private quarters!
I added some photos and will continue to take more. Im just trying to figure out what I have to start with.
I took the seat cover off and it seems part of the original interior is still there. It’s in pretty bad shape, but maybe a starting point for coloring or style. I also found what looks like the original jack behind the seat. Can anyone clarify if the “Realistic” brand radio is original? It also came with another instrument cluster.
Would love to hear her story if she could talk.
327ci V8
1958 Apache 31
Sir Searchalot
Sir Searchalot
thumbs_up
Great job getting her home! thumbs_up
Before you get up on that bouncy diving board and take the plunge, take a little beginning read in Frequently Asked Questions
Down about mid page is a small "essential" fact that is encouraged as "first read" material. Hint - look for "How do I start a restoration? "
Very good beginning advice. wink
Others will be along soon to help and share in your/our madness! shake
Dan wave
~ Dan
1951 Chevy 3 window 3100
That’s a very desirable truck, I’m jealous!
Somebody bought a pretty sporty truck back in the day.
Good luck with your restoration and please keep us updated on your progress.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
The radio in the dash appears to be original. The one mounted to the bottom of the dash is an aftermarket one added later.
Looks like a good starting point!
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Crusty Old Sarge
Crusty Old Sarge
Congrats on getting her home, now the fun begins. Once you get into it and under it you'll be able to tell more about the truck s history. Just from the pictures the engine appears to be the most modified part of the project.
Spend some time and clean things up and you will have a better idea of what is original to the truck and what was added later. Record any numbers you find and share them with the site, a lot can be learned from what find
Still a great find, like D.B. said I'm jealous too
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Realistic was a brand name for some Radio Shack products. I had a Realistic FM tuner as part of my stereo system around 1970.
Authorized Pest
Authorized Pest
If you have some questions about the radio, Fred Nixon is the go-to for any of those questions. Fred's got his spot in The Radio Bench forum.
Looking forward to seeing more about your Task Force. Be sure to post questions in the right forum. It'll help you get the best answers (sometimes multiple answers wink ) to any questions. Breeze down the list and see what's what. thumbs_up
~ Peggy M
1949 Chevrolet 3804
Looks like good bones.
Congrats on your new truck!
There's a flat spot right in front of the passenger side head on the dock that will have the engine code stamped in it...that will tell us exactly what engine you have.
The original jack is a screw bottle jack that is held into a bracket via a long coil spring. It's located right behind the driver's seat.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Rovertech Well it looks like your off to a good start,most stuff is there should be running shortly,once you get so you can get to the gas station you'll be on your way !! Out of about 30 AD trucks in 50 years I always had my best energy when they were driveable. Don't mind being apart for service but don't want to lose sight of the end of the tunnel ! I guess those Mickeys would be OK cleaned up.
Looks like it has a 327ci under the hood. Engine code is V1129YK. Cross referenced another post and it seems to be a late 60s motor. I was kind of hoping to have original motor, but judging by the modifications on the intake, not surprised.
327ci V8
1958 Apache 31
I`d yoink that motor out and go through it and decide whether to put in a 283.
I like the 327 but nothing wrong with a 283. Clean the tank or put in filters.
There are some great plug and play rewire kits out there. Not that hard.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Rovertech Nothing wrong with a 327,is just a stroked 302 more torque, all the supply places can help jegs,summit,speedy bill,it will be listed right after 350 the most commonly rodded engine out there. Hope it's a forged crank version probably will be.
Got a few hours with the truck this afternoon. Got her stabilized on jack stands so I can get to the brakes and undercarriage.
Removed the floor liner to find moisture trapped underneath the underlayment, removed what I could by hand to let it dry out and mitigate any further rust.
Installed a battery and checked controls/gauges: Gas gauge,amps,oil work. Wipers work, but motor loud. Fan works inside as well as turn signals although they are touchy. Headlights on one side work, Highbeams work as well as tailights
Turned motor over by hand and lubricated cylinder walls with oil. Could hear the compression while turning.
Attempted to turn over with ignition, cranks but no fire yet. Ran out of time and will check spark and attempt to pour fuel in carb for next fire
No fluid in master cylinder and didnt get wheels off to inspect further.
327ci V8
1958 Apache 31
Check your ground on the other headlight bucket. That is a really common problem that will keep one side from working.
The toeboards look good. Hard to tell how the rest of floor is from those pics. Looks lime you are off to a good start.
Beware of old gas in tank!
Rovertech,
Just a reminder note that as you get into each different area of your truck, it is best to post on that particular topic (by itself) in the corresponding Tech forum.
You have already done so on the "floor rust" topic (good on you for doing that) by posting in the Paint and Body Shop . Definitely a plus to do the same for your other discussion topics/questions so your conversations don't get jumbled up.
If you want to keep folks up with how your work is progressing in general, you can also post a note here What did you get done... .
Glad to see you are able to actively work on your truck and thanks for sharing! thumbs_up
~ Dan
The truck is going up for sale due to unexpected financial burdens.
327ci V8
1958 Apache 31
Authorized Pest
Authorized Pest
Rovertech, did your truck sell? We can edit your signature line ... laalaa
~ Peggy M
1949 Chevrolet 3804
Page 2 of 2 1 2
