1 members (klhansen),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Have all the Big Bolts people died or gone to? No response last several days?
Ed
| | | | | Joined: May 2015 Posts: 11,149 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,149 | Looks like at least you're alive Ed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 5,997 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,997 | Ed, There still amongst the living I think.  Only been a few days at most since recent posting activity. HFfarms has one unanswered post/question here: https://www.stovebolt.com/ubbthread...inion-seal-part-numbers.html#Post1486692Maybe you could help him out???
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 2019 Posts: 150 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 150 | No worries. I finally got a master parts manual in today and managed to obtain the part numbers I needed which conveniently are no longer available so liquid gasket maker it is! I'll close the loop on that thread shortly with the parts numbers in case someone searches and comes across the thread. I will say that it has been oddly quiet in here this week.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Ed Pruss Well been busy studying the cam and lifter problem,ordered in a Melling CCS-1 looks fine. I happen to have 3 new old stock lifter bodies that have an original grind on the lobe surface to go by ,they are probably 50 years old given to me by an old teacher of mine. From what I've seen not surethe re-grinders are getting the grind that is needed for long cam service. Any ideas on what is needed ?? | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | klhansen Question on tin ware are there any cabs up in cold country where you are ?? Looks like clean original straight tin ware is the best way to go. My corn belt area should generate some big bolt trucks that are clean , last stub nose 51 I looked at would have been a big job to get back into shape ! Know of just one barn find truck (3100) been in the shed about 20 years. I happened to think maybe your area would have some task force iron laying around from the alaska hiway,have you seen ahything like that ??
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gdads51 Been a while since Mongo's ,have cruised in the cold when I could ,aim to go at 5 in the morning and will cruise by that 3100 I spoke of. Will be about 22 degrees in the morning,no problem. Finally getting some sun to soak up the gloom,got a 272 + .080 (261) short block on the stand need to work up an 848 head for it,fresh guides are in it,10/10 shaft ,fresh rings. Went to see my crank grinder man,he is OK need to take him a core and land a shaft and bearings before it gets any tougher. | | | | | Joined: Sep 2009 Posts: 5,997 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,997 | fixite7, Be sure and post in the Spotters Alert forum and report on that 3100 you came across. Know you always work your "Big Bolts" like they were designed for it. Maybe you could post some pics???
| | | | | Joined: May 2015 Posts: 11,149 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,149 | klhansen Question on tin ware are there any cabs up in cold country where you are ?? There's some around, but they're kind of hiding out in the trees (or in some cases "around" the trees.) I looked at a 2 Ton that was for sale a number of years ago, but wasn't in the market for one. The cab wasn't in much better shape than mine was, so it wasn't even a good parts truck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gdads51 Cruised at about 5:30 before daylight,rubber kinda humped. I told Martin I could get pictures to the computer,but have not landed them on SB or BB yet. Need to try again,have a camera with sim card and pictures on it. Been cold raw and windy here.Gdads51 better day today 2/20/23 gonna go roll my 51 3600 thru see if it will start about 55 degrees out,be back. Fired right up has been since dec. 14 th,brakes pumped up too. Got a new master cylinder from Carters quite a while back,don't think it has that soft seal in it because it leaks off the residual. Anyway ran fine no expensive noises.
If you need help posting some pics, send me a PM and we can work on that separately.
| | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | Haven't messed with the Spartan or 6500 in a while. Hopefully this summer both will run once again. | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | I'm on a little road trip with a buddy, my wife doesn't want to travel/camp and I helped with a slide-in camper build for him. Using his camper and my truck, left Michigan on Thursday the 9th, drove 800 miles the first day into Nebraska, then to Moab. We're now camped at the Valley of Fire north of Lake Mead. Next leg will be to Death Valley where my son will plan to meet us and camp for a night. We'll then start making our way back to Michigan, weather will dictate the route to some degree. Internet has been spotty, especially in Canyonlands, and Bears Ear Utah.
| | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 |
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gdads51 Thanks for your offer to help on pictures ,talked to a friend who said pictures are not on a sim card ??? They show up at Walmart when you put it in their machine ? I must have misunderstood him. Anyway have to look at it again see what I have on there,have a card that is nothing but AD trucks. My winch truck looks like a barn find,is so dusty however better than mud !! | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | To be honest, I've sorta ignored this thread in "Active Topics" because I thought it had something to do with DEAD TRUCKS. I don't think dead people are on *this* site. IMHO.  Fix ... we just got to see some pictures!!
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Peggy, glad you are on this post, I wasn't sure if I was supposed suggest moving it. LOL..... A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Peggy M What pictures?? I tried months back and with Gdads help maybe get it done.Had my winch truck out,maybe they hid in the clouds been 2 or 3 months. | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | Paul,
Funny. Some of the posts could go in the Driving or What done or Using truck threads. Or the Spoon! You and Mike can sort it out.
fixite7 ... working this out in a PM. Very interesting!! (Thanks)
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | seeing as how it was asking about the big bolters, (well, we're not all big!) I figured I"d leave it in here. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gdads51 Can't put that 3100 on spotters ,gonna buy it, a classmate of mine from 1st. grade who has passed on parked it. Suspect his son wont let go of it. | | | | | Joined: Nov 2022 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 62 | I am steadily working on upgrading the driveline in my 1950 COE. Engine/Trans/Differential from the 1994 Chevy 3500HD donor truck now in place. Next up will be the front end upgrade to disc brakes, mostly using the Grigg suggestions in the sticky at the top of the forum. IF my recipe works, I will share it. But it is getting hard to find the steering arms for the 3500HD or P3500/P30 front axles with steering behind the axle like the COE.
Marty Mesa, AZ | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Marty, I thought you had found one, might have found the other by now, I will keep looking for a single. I have a full set I have not used yet!
Ed
| | | | | Joined: Nov 2022 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 62 | Marty, I thought you had found one, might have found the other by now, I will keep looking for a single. I have a full set I have not used yet!
Ed Hi Ed, Thanks to your help, I did manage to find a set. My point is, while not impossible, it is hard to find P30 Steering parts anymore. Getting harder to find used 3500HD parts as well, new are available. Its not impossible, but when you embark on the journey laid out by Grigg, patience and persistence is key. I hope to start on my front steering in the next couple weeks and will try and document what I used, and what worked and didn't. if successful. Marty | | |
