5 members (DaveV, Dragracefan, Wayne67vert, Shade Baby, Otto Skorzeny), 136 guests, and 2 robots.
Topics128,149
Posts1,056,819
Members48,456
How difficult is the job replacing the windshield regulator on a 1946 AK model ? The unit under the dash . Anyone done it? Any tips or tricks? Any pitfalls to be aware of?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Danny T,
Although I haven't done this myself, I did find a possibly useful article (not mine) here: https://inthegaragemedia.com/ctp-may-2021-chevs-interior/
It doesn't detail the underdash work involved in removing the regulator once you have managed to get it disconnected from the windshield, but may be helpful with the steps needed before removal.
Another thing you might find useful is this Tech Tip written by member "Kip Bonds" (Kip's41) posted back in 2007 Windshield Crank Rebuild
Am sure that others will come along and add their experience and knowledge to help you with your task.
Maybe you can post more about your progress (with some pix please) as it could prove helpful to the next 'Bolter needing to do this repair too.
Looking forward to seeing how this turns out. thumbs_up
Dan wave
~ Dan
1951 Chevy 3 window 3100
I have done 2 and I don't recall there being anything unusual about taking them out. It has been a few years and my memory is not anywhere close to perfect.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Thank you, guys!!
Hopefully it’ll be fairly simple. I’ll photograph and document my progress.
Danny T
X2 what homer52 said. It will help to do some stretching exercises though, before you climb under there though. If you plan on doing much more work under the dash, a padded plywood plank that rests on the floor board on one end and a supported leg(s) on the outside end will greatly ease the pain. The downside to this, if it’s to comfortable, is a short nap could result.🤫
I’m so glad to read this. I have my regulator out now and it is need of a bushing just as described by the one Kip Bonds did. I now have much more confidence. I think I’ll make a steel bushing however so it may last a bit longer.
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
That bushing should probably be softer than the steel regulator. I would rather the steel regulator arm wear out another bushing than a steel bushing wear out an irreplaceable regulator arm. Just my thoughts.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
