1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1487107 02/09/2023 12:33 AM
7
7 Offline
I pulled a 3 speed transmission from a 63 c10 parts truck last weekend and it ended up being an overdrive. The number on the back is 3743368 the 1168 and 23 is all on the rear part of the transmission. Can anyone tell me what these numbers decode to ?
There are two 3 speed overdrive transmissions that fit Chevy cars and trucks. Both of them use a Borg-Warner OD unit. The Muncie SM-319 has 4 bolts holding the side cover to the transmission case, and the Saginaw transmission has a 7 bolt cover. The Saginaw is an extremely scarce item. Both traqnsmissions require a push/pull cable to lock out the OD when trailer towing or descending long hills. There is also a control relay and a kickdown switch in the throttle linkage that should be scavenged from the donor vehicle.
Crusing in the Passing Lane
Pictures are always helpful!
Ed
79broncoowner,
The casting number "3743368" can be traced back to the "main case" casting code number for the Muncie SM-319 (3-speed w/overdrive) and the Muncie SM-318 (3-speed). Same case used for both versions of this 3-speed.
The other numbers you provided "could" be casting date code numbers, but don't match up with known casting code info I could find???
Ed hit the nail on the head - a picture (or 3) with all these details clearly visible will go a long way in helping you ID what you have.
Dan
~ Dan
1951 Chevy 3 window 3100
7
7 Offline
OK thanks I will get some picture and post them
There should be a casting number on the rear case like R 10 H 1, if it has a rear mount pad it's likely correct for the 63 truck. The earlier version (55-57) car and truck had no rear mount. If it has the solenoid and governor it should be a good find.
Fred
7
7 Offline
Images by Daniel Crymes
Here are all the images in the Flickr account. The first ones show the four overdrive images. This was easier than trying to pick them out of the previous post list.
Maybe 79 can edit this again, to add more explanation.
Hope this helps.
~ Peggy
(Some good pix in there! thumbs_up )
[img]https://live.staticflickr.com/65535/52680043683_03f6883927_t.jpg[/img]IMG_6037 by Daniel Crymes, on Flickr[img]https://live.staticflickr.com/65535/52679546076_e0bf125f0d_t.jpg[/img]IMG_6036 by Daniel Crymes, on Flickr[img]https://live.staticflickr.com/65535/52680043003_8c3bdf08be_t.jpg[/img]IMG_6034 by Daniel Crymes, on Flickr[img]https://live.staticflickr.com/65535/52679982080_ef9f8e03b2_t.jpg[/img]IMG_6033 by Daniel Crymes, on Flickr
79broncoowner,
When you post images from Flickr, please use the link tool (looks like two chain links in front of the globe) rather than the image tool (the one that look like a picture.) Thanks
You can also post pics directly here from your computer (without them being on another website). To do that, you need to use the full editor and the attachment manager below the text entry box. That way they show up as thumbnails and can be opened and scrolled through.
The date Code is I 16 8 which is 9 16 1958, which probably makes it a 59 transmission. Same basic application through 1965.
The rear mount pad was used on cars because of the X frame, not applicable to trucks. The lower bellhousing mount holes were
threaded on the truck case, It has the correct truck side cover as well.
Fred
