| | | Forums66 Topics128,064 Posts1,055,859 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | I pulled a 3 speed transmission from a 63 c10 parts truck last weekend and it ended up being an overdrive. The number on the back is 3743368 the 1168 and 23 is all on the rear part of the transmission. Can anyone tell me what these numbers decode to ? | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | There are two 3 speed overdrive transmissions that fit Chevy cars and trucks. Both of them use a Borg-Warner OD unit. The Muncie SM-319 has 4 bolts holding the side cover to the transmission case, and the Saginaw transmission has a 7 bolt cover. The Saginaw is an extremely scarce item. Both traqnsmissions require a push/pull cable to lock out the OD when trailer towing or descending long hills. There is also a control relay and a kickdown switch in the throttle linkage that should be scavenged from the donor vehicle. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Pictures are always helpful!
Ed
| | | | | Joined: Sep 2009 Posts: 5,833 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,833 | 79broncoowner,
The casting number "3743368" can be traced back to the "main case" casting code number for the Muncie SM-319 (3-speed w/overdrive) and the Muncie SM-318 (3-speed). Same case used for both versions of this 3-speed.
The other numbers you provided "could" be casting date code numbers, but don't match up with known casting code info I could find???
Ed hit the nail on the head - a picture (or 3) with all these details clearly visible will go a long way in helping you ID what you have.
Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | OK thanks I will get some picture and post them | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There should be a casting number on the rear case like R 10 H 1, if it has a rear mount pad it's likely correct for the 63 truck. The earlier version (55-57) car and truck had no rear mount. If it has the solenoid and governor it should be a good find. Fred
| | | | | Joined: May 2015 Posts: 11,047 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,047 | 79broncoowner, When you post images from Flickr, please use the link tool (looks like two chain links in front of the globe) rather than the image tool (the one that look like a picture.) Thanks
You can also post pics directly here from your computer (without them being on another website). To do that, you need to use the full editor and the attachment manager below the text entry box. That way they show up as thumbnails and can be opened and scrolled through.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The date Code is I 16 8 which is 9 16 1958, which probably makes it a 59 transmission. Same basic application through 1965. The rear mount pad was used on cars because of the X frame, not applicable to trucks. The lower bellhousing mount holes were threaded on the truck case, It has the correct truck side cover as well. Fred
