1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14858 06/19/2003 3:10 PM | Joined: Jun 2003 Posts: 4 New Guy | | New Guy Joined: Jun 2003 Posts: 4 | I am replacing the damaged front crossmember on my 53 GMC 1/2 ton. The original crossmember is attached by rivits,so if I replace the crossmember, I will have to use bolts instead of rivits. Is it OK to use bolts instead? Has anyone else done this?
Any advise would be appreciated. | | |
#14859 06/19/2003 4:27 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Just use some quality grade-8 bolts from a good hardware store. Grade-8 bolts have 6 marks, sort of like a * on the bolt head. Get nylon-insert lock nuts as well, and washers, and you should be just fine.
Cheers! George | | |
#14860 06/19/2003 6:07 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Strength-wise, the steel rivets are roughly equivilant to a grade 2 bolt. They weren't used for strength, but because they were cheaper to install in a factory setting. You can use grade 8 if you want, but it's overkill. I would drill out the rivet hole to the next size and put in grade 5 bolts.
Fred 52 3600 69 C-10
#14861 06/19/2003 8:28 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Cost difference between grade 8 and grade 5 is negligible, and they're available at any good hardware store (and some Home Depots). They also typically come with a yellow coating that's rust resistant - unlike the grade 5s. Just remember: you'll never think in hindsight, "gee I should've used cheaper bolts..." -Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#14862 06/19/2003 9:45 PM | Joined: Jun 2003 Posts: 56 Member | | Member Joined: Jun 2003 Posts: 56 | In addition to low cost rivets are used when it is important that there be no movement of the two pieces being fastened and when most of the stress is shear. A rivet completely fills the holes whereas a bolt, even a close tolerance one, will not and allows some movement.
Bolts are better under tension than rivets.
Not only do grade 8 bolts help prevent corrosion but they look cool and we're not talking big bucks here for just a few bolts. I agree that the hole should be made to fit the bolt very tightly and also recommend that a good lock nut or washer be used.
'31 Chevy 1 1/2 ton, '42 GMC 2 1/2 ton 6x4, '52 GMC 2 1/2 ton 6x6, '53 GMC 5 ton
