6 members (klhansen, Peggy M, Maybellene, TexasJim50, Hanks custodian, Woodcmiami), 92 guests, and 2 robots.
Topics128,059
Posts1,055,820
#14858 06/19/2003 3:10 PM
I am replacing the damaged front crossmember on my 53 GMC 1/2 ton. The original crossmember is attached by rivits,so if I replace the crossmember, I will have to use bolts instead of rivits. Is it OK to use bolts instead? Has anyone else done this?
Any advise would be appreciated.
#14859 06/19/2003 4:27 PM
Just use some quality grade-8 bolts from a good hardware store. Grade-8 bolts have 6 marks, sort of like a * on the bolt head. Get nylon-insert lock nuts as well, and washers, and you should be just fine.
Cheers!
George
#14860 06/19/2003 6:07 PM
Strength-wise, the steel rivets are roughly equivilant to a grade 2 bolt. They weren't used for strength, but because they were cheaper to install in a factory setting. You can use grade 8 if you want, but it's overkill. I would drill out the rivet hole to the next size and put in grade 5 bolts.
Fred
52 3600
69 C-10
#14861 06/19/2003 8:28 PM
Cost difference between grade 8 and grade 5 is negligible, and they're available at any good hardware store (and some Home Depots). They also typically come with a yellow coating that's rust resistant - unlike the grade 5s.
Just remember: you'll never think in hindsight, "gee I should've used cheaper bolts..." wink
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#14862 06/19/2003 9:45 PM
In addition to low cost rivets are used when it is important that there be no movement of the two pieces being fastened and when most of the stress is shear. A rivet completely fills the holes whereas a bolt, even a close tolerance one, will not and allows some movement.
Bolts are better under tension than rivets.
Not only do grade 8 bolts help prevent corrosion but they look cool and we're not talking big bucks here for just a few bolts. I agree that
the hole should be made to fit the bolt very tightly and also recommend that a good lock nut
or washer be used.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
