6 members (Stovebolt48, 78buckshot, Shardean, GRNHydra, Ponchogl, dt235sd), 88 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#1485118 01/26/2023 12:24 AM
I have a '41 AK and was getting started on some suspension repairs. The first thing we noticed is that the steering stops are missing and tires are rubbing. I can't seem to find any specific information on the stops. Are they replaceable or do you have to buy new king pin hardware?
ronsway #1485121 01/26/2023 12:40 AM
7
7 Online: Content
The stops on my '57 are adjustable bolts threaded into the rear of the knuckle, they contact a small pad forged in the axle, one on each knuckle.
ronsway #1485124 01/26/2023 12:46 AM
ron,
A check of the 1929-41 Chevy Master parts Catalog accessible on the "oldcarmanualproject.com" site shows the steering stops for your '41 AK have a stand alone part number (see linked page and screenshot with part with red arrow) and don't appear to be part of the king pin set.
1941 AK Steering stop info
To my knowledge, no one is reproducing these. Best guess is put an ad in the Swap Meet Truck Parts Wanted to see if someone may have some spares laying around.
As an alternative, perhaps someone can post dimensions so you might be able to fabricate some replacements???
Screenshot 2023-01-25 at 18-34-37 1929-41 Chevrolet Master Parts.png (601.73 KB, 226 downloads)
1941 AK Steering Stop info
Screenshot 2023-01-25 at 18-43-57 1929-41 Chevrolet Master Parts.png (291.19 KB, 226 downloads)
1941 AK Steering stop diagram
~ Dan
1951 Chevy 3 window 3100
ronsway #1485143 01/26/2023 3:26 AM
Same as on my 46, would be easy to make, start with a 3/16 thick L bracket w/3/8“ hole from a building supply, there is a slight tit on it that fits a depression (to keep it from rotating), drill a hole and drive in a pin to protrude on the back side…
Was just modifying mine as the left wheel could rub on the pitman arm (my tires are a bit wider than stock), drilled a hole in it and threaded 5/16NF bolt so I could adjust the limit.
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Thank you -
ronsway #1485181 01/26/2023 2:44 PM
ron,
Just an update to your post here. I posted the following info to your Truck Parts Wanted ad in the hope it will help folks provide a source for your "steering stops".
Good luck! thumbs_up
Dan
Originally Posted by Gdads51
ronsway,
After a check of a later 1929-57 Chevy Master Parts List (MPL) source here : http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0522.htm, the part number listed in the earlier 1929-41 MPL "3656527" for your "1941 AK" steering stops (same for both sides of the axle) is listed for "1/2 TON, AL, BL (1st Ser.).
It would appear what you need can be found on any of these vehicles, which widens the search pattern for donor trucks.
Sorry about not catching that fact when I posted the 1929-41 MPL data in you "Driveline" post "ronsway" Driveline post .
Hope this helps find what you need. wave
Dan
~ Dan
Dave,
Any chance you could measure these up and provide dimensions?
It looks like they'd be pretty easy to fabricate from some bar stock.
If ronsway doesn't snap them up, I'd be interested in buying them and doing a drawing for other bolters.
Kevin, Ronsway contacted me and I’ll be sending these out to him. Some time this weekend I’ll have some time to take some measurements and I’ll get back w you. Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
thumbs_up
I'm sure there are other 'bolters who could use the dimensions. I assume these get attached with the kingpin wedge bolt (please correct me if I'm wrong).
I suggested that Dave (Flatblu4748) and Kevin (klhansen) conversation about gathering and sharing the dimensions of the "steering stops" be moved here to "ronsway"s original post for all to share in the info.
Will stay here in Driveline for others to share in as it would have disappeared from the Swap Meet posts.
Dan
~ Dan
Dan, Kevin, here you go:
I’d love to have seen the process/equipment that GM used to fabricate these stops. I’m thinking the bar stock was heated red hot and then bent and stamped and sheared with minimal machining required. No way I’ll commit to giving you my version of what the dimensions would be since these are so crudely made. Obviously a whole lot of precision was not required of this part. Accordingly, if anyone wants/needs to make these hopefully you should be able to do so from the following 8 photos:
"Old Blue"
More pix on Flickr
Moved Dave and Kevin's replies here to "ronsway"s post in the Driveline forum so it will be available for everyone to have access to.
Very much appreciate Dave taking the time to measure these up and provide the detailed pictures. thumbs_up
'Bolters helping 'Bolters!!! yahoo
Thanks!!! shake
~ Dan
ronsway #1485377 01/28/2023 1:18 AM
Dave, Much appreciated. thumbs_up
The only thing that might be a little hard in fabbing these is the upset button next to the bolt hole. Although that could be done by drilling a smaller hole and inserting a pan head sheet metal screw on the button side. I assume there's a locating hole on the axle that fits into. I don't recall seeing one on my axle, which is currently buried in snow.
I'll be saving those photos and might be able to produce a drawing from them.
ronsway #1485433 01/28/2023 1:35 PM
7
7 Online: Content
I want to apologize for my previous post on this thread, the steering stops on my LCF are threaded into the steering arms, not the knuckle as I had noted.
