| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Anyone ever put a 1.5 ton on a later model 1 ton chassis? I have a 56 4400 and am considering putting it on a later model (70s-80s) 1 ton dually frame. Maybe with a widened 56 chevy stepside bed to fit over the dual wheels. Make like a hot rod dually out of it. Any Ideas?
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Jun 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 44 | | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Very cool. I was thinking of doing exactly that, but with a '56.
Chris
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you're not adverse to useing fiberglass, ther are 'glass rear fenders availible that are 3" wider than stock. you might be able to save widening the bed too much if you use those.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Thanks for the tip LONGBOX55. Who sells them? Also does anyone know the width from bed side to bed side of a task force era step side bed? Im wondering if the 6 extra inches from the 'glass fenders would clear the dual wheels.
Chris
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | American classic, brother's, and Chevy Duty have them. I just measuerd the 3200, it's about 51" on the outside of the bedsides, you might have to put a mini-tub inside the bed to clear the duals.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Thanks Bill. Looks like "chevy duty" is now called "classic parts". I see they have the fenders, but it says "short bed only!" Why is that? What is the difference in short and long bed fenders?
Chris
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No difference in the fenders themselves, it's the running boards that are different. They don't have the tapered boards for the longer wheel base trucks, only the short ones. Of course nobody ever said that you couldn't fab your own.
