3 members (Lightholder's Dad, 32Fordpuchoptop, J Lucas), 67 guests, and 1 robot.
Topics128,049
Posts1,055,635
#1484419 01/21/2023 1:23 AM
Hello fellow bolters,
It just came to my attention that instead of using a 6 volt battery I can use a 12 volt to turn it over and see if my motor is good, any truth to that?
I have a 6 volt electrical original system, but I don't have a 6 volt battery to try to start it.
I don't plan on driving it or running any electrical equipment, just trying to see if it fires up before I invest in a 6 volt battery. I have good 12 volts at my disposal.
If there is truth in that do I still use the positive on the 12 volt as a negative ground, or hook it up as a regular 12 volt system?
Thanks jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
Yes, you can use it to turn your engine over without any trouble. However, it could fry your gas gauge and it will blow all your lights, if you turn them on.
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Make sure to always tell us the year and make of your project as there are differences between GMC and Chevrolet...it helps us help you!
You can add your trucks info to your signature line in your profile so you don't have to say it each time you post.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Dltalfa #1484449 01/21/2023 12:55 PM
Thank you,
Do I make regular positive to positive, or negative to negative connections? Don't want to create more issues.
Jim
Mike B #1484450 01/21/2023 12:56 PM
Thanks I will
Jim
7
7 Offline
If the truck is still positive ground then connect the positive battery terminal to the chassis ground.
Chevrolet will not be positive ground.
Truck is a 1950 3100 6 volt system with positive ground
Who converted it to positive ground and why?
If you bought it that way, I'd make sure the wire from the coil to the points is (+). I never trust modifications made by previous owners until I verify them myself.
Or, convert it back to negative ground to avoid further confusion or problems. Jump starting , for example.
1950 Chevrolet 3100 (Ol' Roy)
Positive ground would be a GMC not a Chevy. There is a tech tip to address changing (take you maybe 15 minutes) from positive ground to negative ground. Very easy to do.
Ex Hall Monitor
Ex Hall Monitor
If you have a Chevy truck it came from the factory with a negative ground system. Be very sure before you start connecting any battery or it'll get very expensive very quickly.
Cheapskate 1229 Would go with 12 volt neg. ground for jumper reasons and alternator reasons.Any delcotron will be neg. ground and very simple.
