5 members (Otto Skorzeny, 2-Ton, Wally / Montana, Lightholder's Dad, 1 invisible), 117 guests, and 0 robots.
Topics128,051
Posts1,055,730
#1484164 01/19/2023 2:13 PM
Where is the best place to get the window channel runs and what not. That's actuallys fits right?
1953 with a 216
I got the division bar run channel from the Filling Station. I had assumed that it was the same as the rear run channel, which I got from Jim Carter, but discovered that those wouldn't fit. So I have two sets for the rear section. It's pretty universal, except for the size, and may be available at a local glass shop too. The Filling Station has rivet kits for the division bar as well, if you're needing them.
Here is some info on restoring the vent windows and installing run channels.
I purchased the Door Felt Kit, Division bar relining channels, beaded window seals and outer rubber window seals from Classic parts. I had no problems with the products. The youtube video that Kevin linked is a very valuable resource.
Ron - - Dusty53
1954 Chevy 3604
Moderated by  ndkid275, Phak1
