2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | Well, I screwed up today. I was replacing my drivers side headlight on my 1946, (simple enough). I pulled the lights on to make sure it was working before I secured it back into the housing. It slipped out of my hand and the prongs grounded out on the edge of the headlight bucket. All the lights went out and I had a waff of smoke where it touched. I can’t see any wires burned into, but I can’t get ANY of the lights to work.
Any ideas or suggestions?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | How original is the wiring on the truck? | | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | Fibonachu, you are my HERO!!! Sure enough, there is a fuse on the light switch and sure enough, it was blown!! Popped a new one in and we have lights!!! Thank you SO much!!
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | As John would say: ![[elvis] [elvis]](/ubbthreads/images/graemlins/default/elvis.gif) We are here to help. Glad it was a simple fix!
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | As a future note: Whenever doing any work on any part of the electrical system, disconnect the ground cable from the battery first.
1950 Chevrolet 3100 (Ol' Roy)
