5 members (Southerntruck, MRMEROTH11, Gray_Ghost, Peggy M, fonz8261), 94 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
Well, I screwed up today. I was replacing my drivers side headlight on my 1946, (simple enough). I pulled the lights on to make sure it was working before I secured it back into the housing. It slipped out of my hand and the prongs grounded out on the edge of the headlight bucket. All the lights went out and I had a waff of smoke where it touched. I can’t see any wires burned into, but I can’t get ANY of the lights to work.
Any ideas or suggestions?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
How original is the wiring on the truck?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I think the 45 and 46 are the same? If it is all original, it looks like there is a fuse at the light switch:
http://chevy.oldcarmanualproject.com/electrical/wiring/images/45truck.jpg
Fibonachu, you are my HERO!!! Sure enough, there is a fuse on the light switch and sure
enough, it was blown!! Popped a new one in and we have lights!!!
Thank you SO much!!
As John would say: [elvis]
We are here to help. Glad it was a simple fix!
As a future note: Whenever doing any work on any part of the electrical system, disconnect the ground cable from the battery first.
1950 Chevrolet 3100 (Ol' Roy)
