2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1482847 01/10/2023 11:34 PM
Looking for pictures of an AD COE engine layout, specifically intake/exhaust manifolds. (cab off of course.)
What manifold changes would a COE engine need to convert to downdraft use in a 3100 pickup? Would the updraft fit a stock 3100 as-is?
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Install stock 235 downdraft manifolds with carb and air cleaner on your engine.
The carb, air cleaner and exhaust might not clear the steering column in the 3100.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
2 Offline
coes use a different manifold with updraft carb. what year is the coe?
It's a 1950 COE. Engine is a 261.
Finally found an internet pic (attached) of what I assume to be a typical COE layout. It appears I'll need both intake/exhaust manifolds.
Matthew 6:33
H Online: Content
Have you run the casting numbers? A 1950 COE would have had a spray-oiler 235 originally. 261's didn't come out until 1954.
My particular engine has serial no. stamp ending F55N, indicating a 261 from 1955. Obviously not original to the truck. Not in my possession yet and don't know the casting number.
The pic posted above is not my engine. It's the only representative photo I've been able to find showing an AD COE manifold layout.
Matthew 6:33
Skooter,
Sounds like in the end you need to replace the current COE engine "updraft" style intake and corresponding exhaust with a "downdraft" intake and exhaust manifold set like Mike B suggested above to provide best fit when installing the 261 into your 3100.
Looking forward to seeing pictures of your 261 acquisition. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Crusing in the Passing Lane
Nice pictures, what did the disc brakes come from?
Ed
Exactly what I'd hoped to find, thanks very much. I've found conventional downdraft manifolds and a Rochester B (both from a 235) that should work well enough. Bet there'd be room for the updraft arrangement in a 3100 if someone wanted to go that route. Doubt the exhaust pipe angle would match the updraft exhaust though.
Matthew 6:33
hi
the disk brakes came off a chevy 3500
the rear axle was swapped from a chevy 3500. Had to move the spring seats
I retained the original from axle and put bushings in the kingpin holes to accommodate the chevy 3500 front spindles
also my truck has a weber downdraft carb. I modified an aftermarket aluminum manifold. works great
51chris,
I have done a couple front axles like that too, found a place that made bushings to fit for $12. each.
Ed
Moderated
Moderated
I don't have any pictures to share, but I can tell you that converting a COE engine to downdraft use in a 3100 pickup will likely require some manifold changes.
Downdraft manifold, and carb., will work but carb. would stick up above floor level, and cause a problem with access when trying to depress the accelerator. I've run across several like this though the years of my COE Hunting Ventures.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky,
skooter was asking about using an engine taken from a COE to put into his pickup.
There shouldn't be any problems with converting that engine to a downdraft manifold setup as that is standard for the pickups. No clearance issues to speak of in this case.
~ Dan
Bond Villain
Bond Villain
Originally Posted by LaraWalton
I don't have any pictures to share, but I can tell you that converting a COE engine to downdraft use in a 3100 pickup will likely require some manifold changes. It's not a simple task, but it's definitely doable. If you're looking for a more straightforward solution, you might want to check out the kubota b3350 dpf delete kit. It's a great way to improve the performance of your engine without having to make major changes. Good luck with your project, and don't hesitate to reach out if you have any more questions.
Hi Lara -- Thanks for stopping by Stovebolt.com and welcome to our site. Interesting link -- does that programming have *any* application to obsolete/non-computerized GM gas engines? smile
Also, we would be happy to talk to you about advertising on our site, although I'm not sure if it would be a good return on your advertising dollars ... Not too many modern Kubota engines to be found among our users ...
Just checking ...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Skooter Anyone that EVER had experience with updraft system would not use it their daily driver. The last one I was around there was often a lot of expletives from under the truck.
Originally Posted by 51chris
hi
51 Chris,
Do you have pictures somewhere of your build? PIctures of the steering linkage etc?
Sure would be helpful....I would add them to Grigg's sticky at the top of the main page. Would be very good to summarize what you did, what parts you used(and part numbers) and where you sourced everything to do the front end conversion.
Marty
