1 members (Shade Baby), 58 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
#1482413 01/08/2023 8:58 PM
I need to change out the fuel pump on a 235 engine and have an old sealed unit replacement pump that smells really varnished. Before installing for a test I was wondering if there is a good product to soak it in since it doesn't look like I can disassemble it.
1953 3100 Pu
Lacquer thinner will dissolve gasoline varnish, but don't know what it might do to the diaphragm.
Gasoline is a good solvent- - - -just recirculate it through the pump from a separate container while you run the engine on a gravity feed tank for a few minutes.
10% ethanol gasoline is an excellent varnish remover.
It effectively dissolves 70 years worth of varnish clinging to the inside of original gas tanks in pterry short order, causing the varnish to collect down stream into the fuel pump, carburetor and valve guides, gumming everything up.
52 carl From what i'm understanding the varnish and gum are about to wipe out the spare push rods and rocker arms,fortunately you can sttill get valves exhaust at least. My last gum episode was in about 1969 on a customer engine swap. Looks like curtains for fuel pumps too,foreign junk has taken over,saw my pile of carburetors waiting for rebuilder core values to climb.
