5 members (cmayna, 3B, Leo, 39Master85, Otto Skorzeny), 87 guests, and 1 robot.
Topics128,075
Posts1,056,279
Members48,441
#1482632 01/10/2023 12:00 AM
Big Bolt Forum Co-moderator
I have been working on the of my 1948 Chevy. The floor pan cross member on the driver’s side was pitted and thin in places so I thought I’d give making a new one from scratch a try. I made a poster board template to trace onto the sheet metal. There is a step down on the channel so I cut the channel at the two 90* bends up to where it steps down and then I welded them to look like a solid piece. If you ever need to make one, drill the cab mount hole after you cut and shape. It has to line up with the hole in the floor. I had to re- align it. I made a simple dimple tool for the dimple on the cross piece. There two spot welded pieces on the under side I salvaged and welded in.
1948 Chevy 2-Ton
Nice work. thumbs_up
You do know that you can buy those, right? But yours looks good.
7
7 Offline
Nice fab job.
Yes, I saw on line that they are about $80, but where's the fun in that! LOL... I had the material laying around and thought I would see if I learned anything from watching Trev's Blog, and Make it Kustom from YouTube. I only used a throatless shear from Hobo Freight, some angle irons and flange pliers for forming the bends, a step drill bit, a portable band saw, hand snips, mostly my gas torch and a little bit of mig on the backside and last but not least, half a brain. I was happy with the results. I sprayed it with some weld through primer and will install it later. The floor is in pretty good shape and I will put some rust mort on, and fill in some pits, then prime and paint. Anyone know what all those holes are for in that cross member? I know the big one is for the cab mount, but not sure about all the small ones. Drain holes? And what goes through that other bracket that is welded on the bottom of channel? It has a 3/8" opening that goes from one side to the other.
1948 Chevy 2-Ton
K Online: Content
The pipe that goes from side to side is for the emergency brake ,bracket that also is held by the two holes on the floor.The oval holes in the side is we’re the emergency brake rod goes through .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I don't think those smaller holes on the inner side are drain holes, maybe for locating the part in a fabrication machine at the factory.
No idea what that big dimple is for either. I don't think it does anything for structural strength.
You did a good job of duplicating it. Wow $80 now? I paid less than $35 for each on mine, although it was back in 2015.
[on edit] Jim Carter still lists them for under $35, but I don't blame you for building your own.
[another edit] LMC sells them for about $25.
My bad, I was thinking rocker panels in Canadian "pesos"at $80. I have a hand lever parking brake, guess that's why I didn't realize what they were for. One of the slotted holes did have a rock hard rubber delete in it, but I didn't realize it was a delete. By the way, I never think of LMC when looking for parts, I usually look at The Filling Station, Chevs of the 40s and Jim Carter.
1948 Chevy 2-Ton
I forgot you were in Canada. Makes a bit more sense when you said $80. You guys usually get stuck on shipping charges like I do in Alaska. That's why I loaded up on parts on a visit down to the Lower 48 a few years back. I dropped a bunch of $$ at Jim Carter and Mar-K on that trip. I could write off the fuel it cost me as "vacation."
The Filling Station has been my go-to lately. Have only ordered one thing from LMC.
Very nice. I thought about doing the same, but prices were to cheap to put that much effort in.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Very nice job. Looks better than the factory made one.
That is some pretty work right there! I enjoy that type of challenge myself. I did a lot of that kind of work 30 years ago on my first truck before I found Stovebolt.com.
I love what this site has taught me, but I do miss the days of doing it the "hard way" sometimes.
