| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Found an old non inductive timing light but am missing the spring like connector used to connect the light to the spark plug. One end attaches to the spark plug and the other to the spark plug boot. Any ideas where I might find one? Online search was not successful. Thanks. Ed
Ed
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Just use a regular spark plug wire with the distributor end insulator boot cut off . No need for a springy thingy! Jerry
| | | | | Joined: Sep 2009 Posts: 5,778 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,778 | Ed, Jerry's solution is probably the best for what you need.  Just for further edumacation, check out this link from another automotive site that some folks provided some alternative solutions: Spring Thingy replacement solutionsInterested to see/know what you decided to use and how it worked???
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | You guys make it too easy!! Thanks...I was really over thinking it. Ed
Ed
