3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#148242 09/11/2006 10:14 PM
Junior Member
Junior Member
I know they mean Gross Vehicle Weight and Gross Combined Vehicle Weight, at least that what I think they mean. But does that mean the weight of the Vehicle and the weight it can carry or what? How about an explanation for us dumb country boys? :confused:
#148243 09/11/2006 10:27 PM
You are correct in what they mean and the way I understand it GVW is the weight of the vehicle and load combined for one weight. GCVW is the same thing with a trailer included. I hope this helps and I hope I am correct! Oh yeah, I resemble that dumb country boy remark!! Ha, Ha! :p R&G
#148244 09/11/2006 10:32 PM
obsa,
I might not be much up the food chain from you...I had to look it up myself a few days ago.
GVW means the total weight of the truck, driver, his dog and cat, and all the stuff in the back that the truck is designed to carry.
Could GVCW be a derivation of GVW?
I am not sure what the designation for the empty truck [tare weight] would be, maybe "curb weight".
Stuart
#148245 09/12/2006 12:08 AM
Junior Member
Junior Member
That is about what I thought, so the tag on my Truck (actually a GMC 350 series) has a GVW of 16000 and a GCVW of 26000. What I am really wondering is what is this , 1 1/2 ton, 2 ton, or what? Thanks again.
#148246 09/12/2006 2:06 AM
16,000 GVW is generally called a 2-ton.
It's the same rating as a 5000 or 6000 series Chevrolet, both of which are called 2-ton trucks.
#148247 09/13/2006 3:13 AM
Junior Member
Junior Member
How do they come up with the 1 1/2 ton, 2 ton... ? I thought my c50 was a 1 1/2 ton. The truck's tare weight is about 9000 lbs. and I've come out of the gravel pit a 24,000. I'm no math wiz but that's more than 1 1/2 tons I'm hauling.
#148248 09/13/2006 3:39 AM
1 Ton, 2 Ton, Etc. is what is called a Nominal Ton Rating. This is a holdover from the 1920's when it gave you a payload rating for the truck. Today, GVWR (Gross Vehicle Weight Rating) is the definitive rating. It includes the truck, payload, fuel, lubricants, driver and so on. GCWR (Gross Combination Weight Rating) includes the maximum trailer weight along with the truck and load
51 Chevrolet Canopy Express
02 K25 Duramax Crew Cab
#148249 09/13/2006 4:02 AM
I think the c50 is in the 1.5T category, the c60 is a 2T, but as Steve sez that terminology is misleading, and the actual GVW rating varies with wheel and tire sizes ... w/ an empty weight of 9000 and a GVW of 16000, you should be able to carry 7000# legally, as the registered GVW is the max allowed by the DMV, and when new the truck would be warranteed to the 16000 GVW, damages or accidents resulting from weights beyond that are your fault ....
the GCW of 26000 means when the truck is loaded, you can pull a trailer with a gross weight of 10000, again legally, and to be within the OEM limits
I've regularly carry over a ton of apples on my 1/2T long box, w/ a GVW of about 4500 I think, and an actual weight of 3500, according to the title
