4 members (SNOYL, Paul_WNC, 78buckshot, Phak1), 58 guests, and 6 robots.
Topics128,012
Posts1,055,320
Members48,419
#1481987 01/06/2023 2:02 AM
Seen a 4 speed transmission a guy wants to sell. Not quite sure what it is but I will show you Bolters a few numbers stamped in on it. They are 5K117364 T101B T10K7.. Let me know if you guys come up with something, thanks.
Crusing in the Passing Lane
Picture would be very helpful!
Ed
It sounds like a Warner T10. It could be the close ratio version used in Corvette's. However they were also
used in Ford vehicles but had different bellhousing mounting.
Yes, pictures.
Fred
The T-10 was the first 4 speed passenger car trans available back before the Muncie came along. B-W made it by redesigning their T-85 heavy duty 3 speed and moving the reverse bits and pieces to the extension housing, leaving room in the main case for another forward gear.
Not quite sure how to show a picture here on the reply. Figured those 3 separate numbers would help, course that's what I get for being sort of lame, just kidden?
Photo instructions are in the left margin of every page unless your on your phone.
