| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | Seen a 4 speed transmission a guy wants to sell. Not quite sure what it is but I will show you Bolters a few numbers stamped in on it. They are 5K117364 T101B T10K7.. Let me know if you guys come up with something, thanks. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Picture would be very helpful!
Ed
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It sounds like a Warner T10. It could be the close ratio version used in Corvette's. However they were also used in Ford vehicles but had different bellhousing mounting. Yes, pictures. Fred
| | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | The T-10 was the first 4 speed passenger car trans available back before the Muncie came along. B-W made it by redesigning their T-85 heavy duty 3 speed and moving the reverse bits and pieces to the extension housing, leaving room in the main case for another forward gear. Jerry
| | | | | Joined: Jan 2022 Posts: 113 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 113 | Not quite sure how to show a picture here on the reply. Figured those 3 separate numbers would help, course that's what I get for being sort of lame, just kidden? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Photo instructions are in the left margin of every page unless your on your phone.
