0 members (), 138 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
Happy Friday to All,
I was getting ready to install my engine in my 51 and I noticed I'm missing the top plate on the front mount.
Top piece in the attached photo.
I don't want to buy the entire kit and was just going to make one from scratch.
I was wondering if anyone knows or can measure how thick that piece is.
My assumption is it is fairly think 1/8 inch because it has to support the engine weight and transfer it to the rubber mount.
Have a great weekend.
Scott
The top piece in the photo is an oil/dust shield.
Haven't had one in my hand for a while but I'm guessing 18 or 20 gauge sheet metal.
Steve
Steve
1946 1/2 ton
I think the top piece is more like 16 gauge. You can buy them separately. Link
If you want to fabricate your own, I could measure the thickness of mine for you. But for $12, just buy one.
Thanks for the link.
I couldn't find just the cover for sale.
I will definitely just buy it.
I'll just have to work on some other stuff while I wait for it to show up.
Thanks again,
Scott
AD Addict & Tinkerer
As Wheelie has pointed out, the top is only a thin cover. If the piece your talking about “supporting the engine weight”, it the next one down and is about 1/8” thick. Unfortunately, if that is the part you need, I couldn’t find it on line. You could post an ad in “Truck Parts Wanted” or fab one as you originally wanted to. Good luck!
Phil
Project Journals
Stovebolt Gallery Forum
The real work of supporting the engine is done by a couple of steel sleeves embedded in the rubber isolator. The rubber isolator piece is available separately as well.
