2 members (Otto Skorzeny, tclederman), 41 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1481940 01/05/2023 10:26 PM
Hello, there is a rubber bushing of some soft in which the bolt runs threw it , does anyone know if these are reproduced? 1950 -1/2 ton
1953 with a 216
Yes, there's a rubber bushing in there, with a steel sleeve. They're not reproduced, but you can send your axle mounting bracket to Steele Rubber who will revulcanize it for you. Or you can get some pourable 2-part polyurethane and do it yourself.
Are these a replacement? Bushing Bolt With Nut Rear End To Spring
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Those looks like they'd work. I was not aware they were available. But you still have to get the existing rubber out before pressing that in. Heat it up to burn the rubber out.
The part number is 3652182.
You can take some measurements and go here Rubber Incased Bushing Type 1 and then do a search for the bushing number and you might find the bushing cheaper.
Or if you have deep pockets. Filling Station
1953 with a 216
