3 members (1955 1 Series, Otto Skorzeny, Greg_H), 49 guests, and 1 robot.
Topics128,024
Posts1,055,395
Members48,422
#148186 09/07/2006 11:59 PM
Junior Member
Junior Member
Where do I start? I have a '49 Chevy 3800 dually and want to get rid of the split rims. I want to use new wheels that will support better truck tires. I want to do this now since I have to replace all 6 tires.
HELP!
#148187 09/09/2006 2:37 AM
I have some 19.5 tubless wheels that will fit that 3800, how many do you need?? 1-918-542-3871 or E-mail [email protected] Thanks Tom
#148188 09/10/2006 1:22 AM
That's what I would do, and run 8R19.5 tires.
They will fit, I have them on my 1 ton, and are a tad taller than the 17" ones I had.
If you must have your original centers with new rims, call Stockton Wheel. They may be able to help you. Be prepared to wait a long time and listen to lots of excuses as to why your wheels are not done yet, some of them actually being true.
1952 Chevrolet 3800 pickup
---All pictures---
#148189 09/10/2006 9:40 PM
If you have the original rims they should be 7.00 x 18 three-piece like I have on mine. After some significant research and pondering, I think I'm going to go with the 19.5s I found on a 58 or 59 (not sure which) Chevy Viking that's in a junk yard nearby. They're tubeless one-piece rims and the bolt pattern, lug nuts, and center hole are the same (by eyeball - I'm taking one of the original rims with me next time I go). The off set appears to be right as well. Good luck in your search.
Jim Blake
Help support the Leukemia & Lymphoma Society (www.lls.org) through Team in Training (www.teamintraining.org). Help put a stop to ALL cancers.
My truck: '49 3800 Stakebed/Dump
#148190 09/11/2006 12:00 PM
Junior Member
Junior Member
Thanks guys. The search is on.
1949 Chevy3800 Stake body dump
Steve McCreary
#148191 12/08/2006 2:30 AM
Junior Member
Junior Member
Would any wheels from this site work?
They have 8 x 6.5", but not sure of the hub size. What about lug nuts?
www.ricksontruck.com
#148192 12/09/2006 3:39 AM
They will.
I traded them 4 of the rims that you are looking for when I bought my Goodyear G171 8R19.5 tires from them, great price.
They stock the wheels you need, and are great people to work with.
Grigg
---All pictures---
#148193 12/11/2006 4:34 AM
Junior Member
Junior Member
Quote
Originally posted by Grigg:
They will.
Grigg
As an option, would 17" wheels with the same pattern work? Would they clear the brakes?
This is a lower cost option.
#148194 12/11/2006 10:51 AM
17" 8 lug duals may be hard to find? I don't recall seeing any.
The 19.5 wheels should be very easy to find in a junk yard.
---All pictures---
#148195 12/12/2006 1:29 AM
Junior Member
Junior Member
Quote
I thought most newer duallys were 17's.
He'd never go for a junkyard wheel. Where can I look online besides Rickson to price 8R 19.5's? It appears as though the '49 won't handle a 225 or 245 due to width.
