I think the frames should be the same (except minor differences in the front crossmember, but the frame horns should be the same). So you should be able to use the Chevy bumper brackets (available aftermarket) and bolt it right on.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
@Djg: I think you will have to make custom brackets. I made my own brackets for my rear bumper. I bought a reproduction chrome bumper. Brackets were made of 2" square steel tubing and angle iron. I described the brackets in this post: https://www.stovebolt.com/ubbthread...per-brackets-on-53-3100.html#Post1348815
Should be able to do something similar for the front bumper.
